Old 03-16-2017, 11:58 AM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
RCA didn't succumb to cost cutting! It was high time, they incorporated intercarrier audio. Everyone else was using it!
Good old Davey, didn't want to pay Motorola the royalties. He just liked collecting them.
I have to get back to my 621TS, haven't touched it in months!
My experiences with the KCS-47 chassis tell me otherwise. RCA did succumb to cost cutting, and how!
Old 03-16-2017, 01:25 PM
Gleb's Avatar
Gleb Gleb is offline
I could advise you to check the IF transformers with an ohmmeter, you might disturb their pins while recapping. If even one of the windings gets opened, you loose the signal completely.
BTW, I've never seen a bad interstage mica.
To understand a bygone era, you should use things from it
Old 03-16-2017, 11:13 PM
Penthode's Avatar
Penthode Penthode is offline
I wasn't referring to just the move to intercarrier. RCA reduced the number of IF stages and cheapened the sync circuitry and dropped DC restoration.
The loss of the video IF stage means that about 1MHz of video response was lost. I suppose the loss of picture detail was worth the cost saving.
There was a couple of RCA B&W models with four VIF stages in 1953 but I believe they were gone in 1954.
I believe the best RCA B&W sets were built between 1948 and 1952. (The cheapened kcs47 chassis is an exception). The kcs66 (Million Proof) sets were the epitome: they employed intercarrier sound, four video IF stages, DC video coupling and keyed AGC. They went downhill from here.
Old 03-17-2017, 10:45 AM
Penthode's Avatar
Assuming the wiring to each stage is correct and the tubes are conducting and the tube dc voltages are present, then evaluating the IF alignment can begin. Replacing the capacitors and altering the wiring dressing, will dramatically affect the staggered tuning. There is a lot of gain in the VIF strip and if the tuning of two stages coincide, the strip will likely oscillate resulting in a total loss of picture.
To determine if the VIF is oscillating, measure the dc voltage across the detector load resistor with no signal input. There should be no DC (less than one volt DC). You need to test this first. Reducing the contrast control will increase the bias on the first stages (there is no AGC in the ts630). If the IF is indeed oscillating, you will reach a point the dc across the detector load will dramatically drop. It is important that the IF strip is not in oscillation before proceeding.
Next, rough alignment is first achieved by injecting a signal stage by stage and tuning each of the staggered stages to what is recommended. Then as each stage is tune to its recommended frequency, you would use the sweep generator to review the combined stagger tuned response.
Follow the RCA published data for the ts630 and it will say essentially the same thing.
Old 03-17-2017, 06:53 PM
benman94's Avatar
Resident Lunatic
I have a 17T150 in the collection, chassis KCS-66, the 'Colby'. If it doesn't have a better picture than my 630, then it is a very, very close second.
Old 03-17-2017, 07:56 PM
Penthode's Avatar
Could it be that the size of the picture compared to the 630 distracts from the resolution?
I once saw a Colby and it had a very good picture. Have you put a resolution chart up to check the frequency response?
Old 03-17-2017, 08:10 PM
benman94's Avatar
Resident Lunatic
I haven't checked with a resolution chart. I aligned it though; I'm nearly positive it's making it out to 4.0 MHz. It's probably just the larger jug and the more visible scan lines that make the image look a bit softer. The mind can play tricks on you; never trust your eyes. Also note, I said the image was nearly as good as the 630. That's a pretty solid standard to measure up against.
Old 05-26-2017, 08:06 AM
Montman Montman is offline
Has anyone with an RCA 8TS30 had to order those wire wound power resistors and the riveted in voltage divider? I'm having problems finding replacements and just what to order for a work around.
Old 05-26-2017, 08:08 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Ohhhh yes. In fact, I do that every time I rebuild an 8TS30. This may help
Old 05-26-2017, 08:54 AM
N2IXK's Avatar
N2IXK N2IXK is online now
Technohippie
Generally, I use 1.5 K and 250 ohm 25W Ohmite 210 series adjustable wirewounds to replace the 2 sections of R185. Both resistors will stack perfectly end to end on the original mounting hardware. Set the adjustable tap bands to get the odd values of resistance needed. Order the mounting washer kits (p/n 7PA25) with the resistors, as the OD of the new resistors is smaller than the original.
The riveted in "candohm" resistor (R186) can be replaced with a pair of chassis mount 10W power resistors (Ohmite HS10 series or similar). I use 6.8K and 100 ohms, as the closest standard values, with no problems. You will need to drill new mounting holes, after removing the original resistor.
Old 05-26-2017, 10:01 AM
That's what I did too. Notice the sliders are near the extremes to get 1360 and 230.
Next time around though I think I'll use a 1.5K and 250 ohm fixed and parallel them with resistors to get the exact value. Fixed are half the cost of the adjustable ones.
15K in parallel with the 1.5K
2.7K in parallel with the 250
2W should be enough. Most of the current will be running through the big power resistor.
Old 05-26-2017, 10:50 AM
benman94's Avatar
Resident Lunatic
I used a 1.5k and 15k resistors in parallel for the 1360 ohm, and 390 ohms in parallel with 560 ohms for the 230 ohm resistor.
Old 05-26-2017, 12:56 PM
Great suggestions guys. What company is best to purchase from?
Old 05-26-2017, 12:59 PM
What did you do for the R209? The 5300 segment is open. The connection is on the middle of the three pronges at the top. Is that 5300 + 500 for 5800 ohms since the three top pronges are for the 500 ohms and the connection is on the middle pronge. What value is it? 5300 or 5800 ? And any suggestions for best place to get it.
Thanks Bandersen for the pix. I try do nice work too.
What's the difference between the 8TS30, not the 6TS30. The schematics look the same.
Old 05-26-2017, 01:38 PM
benman94's Avatar
Resident Lunatic
The 630TS has an electromagnetic ion trap; 8TS30 is PM. I think some of the 630TS sets have a field coil speaker; all of the 8TS30 sets, and most of the late production 630TS, should have a PM speaker.
