Anyone have a Motorola SAMs Set 122 folder 5
I just want to know the value and wattage of two high watt resistors , one connects from one pin of an electrolytic to another electrolytic , the other from electrolytic to I think the power transformer.
Thanks |
R88 5W
R89 10W R90 2W
Kevin thanks but what are the values of them , the picture you have a link to I can see but not clearly , it says I have an unsupported browser.
Mike |
Left to right they are 1.5K @ 2W, 375Ohm@ 10W, 5K@5W
Fixed above link to go directly to image.
Kevin , thanks I can see it now.
Is the 10watt resistor part number 700782 ? |
Yes, with the exception Sams lists a 17K prefix.
I know have it recapped and thanks Kevin for the assistance with the resistors , I powered it up and there is no vertical sweep , is this Set similar to chassis ts-95 ?
If so I can go by that schematic to work on the vertical , link below to the service manual. http://www.earlytelevision.org/pdf/M...94-TS95-v2.pdf Mike |
Give me a couple hours and I'll scan Sams 122-5 for you. PM me your email and I'll send it when it's ready.
I also forwarded the Sams 122-5 to the ETF so Steve can post it if he wishes.
