Old 10-26-2017, 12:09 AM
reeferman's Avatar
TV as light source?
Update. Solved. See below.
Samsung UN55J6200 LED TV.
Yep, the thread below this one.
The screen turned out to be bad, so I figured the set could be used as a light source if I removed the damaged screen. Right?
I removed the screen, and oh what a light source! Only problem is it flashed a few times then quit at the 2 minute mark. Having a second set of boards, I installed them (the T-con board had no screen to attach to) and the same thing. The screen lights up, then flashes a few times, and is dead by the 2 minute mark.
Any ideas??
Thanks
Old 10-26-2017, 12:33 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
The computer probably has programming that says if it doesn't detect a working screen by two minutes then turn off. I'm assuming you mean it's an LCD tv with an LED backlight. Well, coming up with a separate driver to run the LEDs shouldn't be too hard. But it kinda defeats the purpose of using the broken tv parts... :/
Old 10-26-2017, 12:48 AM
Most newer sets will shut off if they don't detect a signal within a set time. It might be defeat-able but without a screen you can't access the menu to change it.
Old 10-26-2017, 01:03 AM
reeferman's Avatar
Solved!
I removed all boards except the combo SMPS/driver board.
Works like a champ.
The light comes on when plugged in wall outlet. No internal on/off switch necessary.
TY
