Old 10-27-2017, 12:49 AM
yrly's Avatar
yrly yrly is offline
Breaking records is good?
Service manual for Audiovox AVT-950?
Anyone got a service manual for this? Might be made by Sampo. It's a 10" CRT runs off 12V probably came from a conversion van. Likely was never used. I wanted to use it as a monitor for a Timex Sinclair.
Anyway I used a nice stable 12V 4.5 amp source which is plenty to power it, issue is it doesn't seem to have any sort of contrast control. When it's in a bright screen the material is too dark unless you set the brightness up, if it switches to a dark scene than the material is washed out. Could use some other minor adjustments as well.
-Give me Fisher or give me Death- yrly
-If it's free, it's for me! - yrly
-when you lose track of the receiver count you know you've got too many
Old 10-27-2017, 08:35 AM
For manual see if it has an FCC type number on the
back. If so run it on FCC.gov & it will tell you original
make & model. Works for monitors too !
BTW is this a B&W or color ?? Sounds like it may be CRT.
Old 10-27-2017, 10:38 AM
yrly's Avatar
It's a small color CRT. And no there is no FCC type number. I speculated Sampo just because the flyback had a Sampo sticker in it and I thought I saw Sampo on one other part. Didn't see any immediate part number jump off the pcb either.
