Old 01-01-2018, 07:04 PM
Gregb Gregb is offline
Rca 21tc205
I am working on my RCA 21TC205 and have it all recapped and pretty much all new resistors and it is working pretty good but there is one issue I was hoping you guys might help me with. When ever some text appears on the screen it has what I will call a shadow following it. This also occurs when a square object appears, trails or shadows follow the corners. I did an alignment per the RCA manual I have for it and some adjustment was needed and it does get very good reception other than this issue.
Any thoughts?
Gregb
Old 01-02-2018, 01:08 PM
That is probably smearing or ringing.
Did it do it before the alignment?
If so have you tested your RF signal source with another CRT TV that is known to work and confirmed there is no smearing in the signal source?
If not can you put the adjustments back?
Have you tried the fine tuning adjustment?
On vintage TVs it is best NOT to align the video IF (and to an extent the tuner) unless they are not allowing a reasonably good picture. It takes a good deal of skill, experience and calibrated signal generation equipment to make an improvement on the original alignment.
Does your set have a DC restoration circuit or DC coupled video circuits between the detector and CRT? Sets that lack DC video coupling and restoration sometimes have a certain degree of smearing on sharp monochrome transitions by design...We get used to modern color TVs that have all have DC restoration and forget what it looks like on monochrome sets where it was not considered a standard design requirement.
Old 01-02-2018, 08:28 PM
I have a number of other sets that don't do this so I think my source is OK. It did not get very good reception before the alignment and there was almost no sound. The sound and picture are now very good other than this issue. Its not annoying by any means so I am not overly concerned but thought if there was something easy to try I would give it a go.
Gregb
Old 01-02-2018, 09:29 PM
Penthode's Avatar
Penthode Penthode is offline
Can you provide some screen shots?
Old 01-03-2018, 07:41 PM
I will try to get a shot of it tonight.
Gregb
Old 01-09-2018, 09:51 PM
Penthode's Avatar
Gregb
Still curious and waiting for a picture or two
Old 01-09-2018, 11:34 PM
I have tried and can't seem to catch the issue with my camera. I think I will just leave it as is and not worry about it. The couple friends that have seen it say it looks great so maybe I am being to picky.
Gregb
