Old 01-20-2018, 10:05 PM
Guys,
I really appreciate those photos. I have to agree it's cream color.
A trip up to the local Walmart produced another bottle of paint. "Toasted Marshmallow" it is.
I redid the lettering on the cabinet and Channel Plate. After it dries tomorrow, I'll clean them both up and outline what I'm doing to mount the Channel Plate.
Old 01-21-2018, 06:00 AM
decojoe67's Avatar
Perfect Crist! It's those little details in restorations that make a set look just right.
Old 01-21-2018, 07:53 PM
Absolutely!
Old 01-21-2018, 08:01 PM
Channel Plate.
I used my heat gun and gently heated and flattened out the plate the best I could. After trying to fit it back onto the cabinet, I could see that the plate had shrunken some. To get the plate to lie flat I filed the round mounting holes till it fit properly and centered over the hole in the cabinet.
With the holes filed out I knew the brass retaining clips won't work. So I came up with the idea of using some #6 flat washers and some 1/8" model airplane fuel line. The fuel line is a tight fit over the mounting posts. The washers are just the right size to go over the posts and then the fuel line can press against the washers "pulling" the Channel Plate onto the cabinet. The pieces of fuel line were left long so if I had to remove them I could grab it with a pair of pliers.
Old 01-21-2018, 08:08 PM
I then recreated the 3 labels. Two for the chassis and one for the back. Not an exact copy but real close!
Once the 2 labels were applied the chassis was done!
Old 01-21-2018, 08:12 PM
The cabinet parts were reassembled and the chassis slid home and screwed down tight!
Old 01-21-2018, 08:27 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Wow. That set looks like it just came out of the box. The channel number plate is made of Tenite which always shrinks and warps to some extent. I had a Westinghouse wood radio with Tenite knobs that we’re slightly misshapen. It is unavoidable. Congratulations on such a fine and detailed restoration. I have bought two of those years ago but both arrived with the cabinets smashed. No one knows how to properly pack and ship something as heavy as a Bakelite TV.
Old 01-21-2018, 10:28 PM
I changed out the interlock cord and replaced the label.
On the interlock I used 2 small nylon spacers 1/4 diameter and 1/4 long. Then used 2 rivets and peened the end over.
Old 01-21-2018, 10:31 PM
Thanks for the kind words.
Old 01-22-2018, 12:19 PM
I missed posting these photos of O'scope curves I took during alignment. The first one shows the initial response curve before I tweaked anything. Then the rest are self labeled.
Then these are from the RF and Mixer adjustments for channel 4. BTW, channel 3 looks very similar.
Old 01-22-2018, 12:43 PM
Notimetolooz's Avatar
Looks pretty good!
Old 01-22-2018, 12:56 PM
Originally Posted by Notimetolooz View Post
Looks pretty good!
Thanks.
Old 01-22-2018, 01:15 PM
Just to include a summary of what was changed during the restoration.
Capacitors:
This chassis has about 72 caps.
21 paper caps that were all changed
6 electrolytic caps that were all changed
There were 4 disc caps that I changed that were on the high side of tolerance.
There were 6 mica caps that were changed. 2 were from the IF can on the tuner. 2 were 1Kv caps that were in tolerance but were changed because of the high voltage rating, the other 2 were in tolerance but changed anyway.
For a total of 37 caps changed or 51%.
Resistors:
This chassis has about 72 resistors. All were changed.
54 resistors were out of tolerance. Some just barely all the way up to 278%.
Of the 18 left, 6 were just a few points from being out of tolerance and were changed anyway.
Of the 12 left, they were well within tolerance. 4 of them from the tuner that got changed while I was "in there" changing the 4 resistors that were out of tolerance.
So looking at percentages:
75% out of tolerance
8% close to being out of tolerance
17% well within tolerance.
Tubes:
18 tubes - 1 was shorted when I received the TV.
4 were on the low side of green.
The 5Y3G rectifier tube was installed but should have been a 5U4G tube due to the transformer being one of the small percentage chassis that got a transformer from a vendor that didn't quite meet the specs for using a 5Y3G tube.
The 7JP4 CRT displays a good picture, not a great one but a very good one though.
Old 01-22-2018, 09:25 PM
decojoe67's Avatar
Wow Crist, that really is a jaw-dropping resto! It looks like the day it was bought new. I would call Admiral the "Chevrolet" of vintage TV's. Great lines and great performance.
Old 01-23-2018, 01:33 PM
Lookin good
Were you able to totally eliminate those white lines/streaks in the video?
