Old 08-31-2018, 09:59 PM
mrjukebox160 mrjukebox160 is offline
The Chassis broke? Unrepairable?
Old 09-01-2018, 12:42 PM
TUD1's Avatar
TUD1 TUD1 is offline
Kig's TV Service
Something on the chassis shorted and I have been unable to take it in for repair.
Old 09-01-2018, 01:19 PM
Then DIY! Power supply shorts are not hard to fix. I recently walked another member through it on a CTC-16.
The best way to learn is to track down any mistakes you made and fix them...The only way to not make the same mistake twice is to know what you did the first time.
Old 09-01-2018, 01:50 PM
TUD1's Avatar
Kig's TV Service
You clearly have not seen my deplorable working conditions. In depth electronics repair is impossible, fix one thing, break three more things. I have no workshop and no money for parts.
Old 09-01-2018, 04:43 PM
So you have a place to work in.
I fixed my first roundy with 6 sqft of floor space sitting on the floor with the chassis.... back then I had squeezed a collection that filled a good sized room in a house into a room in an apartment half the size... there was no wall space not covered by electronics, and most of the time only a goat path between the bed and door.... home is where you hang your hat, and a work bench is anyplace you can set a chassis, DMM, and soldering iron...
No parts?.....I once recapped a RCA 630 chassis with only series/parallel combinations of only .05 and .01uF caps because all I had was 2 big bags of them and no money.... when the going gets tough it is time for enginuety.
Old 09-03-2018, 01:31 AM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
That's not that bad, I yanked the chassis out of my CTC-21 and recapped the power supply on my kitchen floor. The work bench is covered in crap and the other table is covered in dead DILA projector and a Marantz 2230 getting a power amp recap. It was also an emergency as my projector died, the Motorola was having intermittent tuner/horizontal/vertical issues and I wanted to watch some damn TV.
Old 09-04-2018, 08:22 AM
AlanInSitges's Avatar
There is a prolific YouTube TV repair guy who does most of the work on the ground in his (or someone's?) driveway. Your working conditions are vastly better!
Old 09-04-2018, 11:01 AM
I've done that too (minus youtube). Over a decade ago mom was worried about solder fumes poisoning me and I was made to do that work outside in the burning Florida sun with mosquitos dogging me...If your wearing shorts never wave a soldering iron around to chase off hovering mosquitos molten lead can drip on some rather tender areas.
Old 09-05-2018, 11:19 AM
When I was a kid I had so many burns on my hands and legs from errant solder. Luckily most of the time it cooled enough on its trip through the air that it didn't do grave damage.
Old 09-05-2018, 01:07 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
That happens to me all the time, one just gets used to it. The same goes for accidental cuts. If I were to drop the iron though I would get out of its way at emergency warp. I burned my hand with a soldering iron once, it hurt like crazy and left a white blotch.
One time when taking apart can caps, one flew apart suddenly and I got splattered with hot tar. That was considerably worse than getting splattered with molten solder.
