Old 02-10-2019, 03:43 PM
Nice! (obviously the det.diode is not backwards).
Thank you.
Originally Posted by electronjohn View Post
Super! (Nice metalwork on the HV cage, too!)
Thank you.
Old 02-10-2019, 07:18 PM
Tom9589 Tom9589 is offline
Isn't it a little odd that they recommend pulling the Horiz Multivibrator tube? Won't lack of horiz drive cause the Horiz Output to red plate?
Old 02-10-2019, 10:08 PM
I tackled the yoke and the centering/focus ring tonight. When I took the assembly apart, I found the centering adjustment real rusty.
I then grabbed the one that came in the cabinet and it was rust too but as much. I cleaned it up and reassembled it using some light grease.
Old 02-10-2019, 10:09 PM
Originally Posted by Crist Rigott View Post
Here is a section of the schematic from Sams. It is R9. Below it are the Alignment instructions that talk about setting the Bias Control. Frankly, how or why its there is above my pay grade.
It is probably an AGC level control. AGC is a feedback circuit that (if keyed) measures the sync pulse amplitude in the video stages (otherwise it just measures average video amplitude over roughly a frame) and varies the gain (via IF and or tuner grid bias) of the IF and or tuner to hold the video level constant...This compensates for differences in signal strength between stations and holds contrast constant in fading signal conditions (such as fringe or DX conditions).....Basically, it makes the contrast control a set and forget adjustment rather than a keep a hand on it at all times and throttle it adjustment.
Old 02-10-2019, 10:20 PM
I then cleaned the yoke and replaced the 3 resistors and 56pf ceramic cap.
Old 02-11-2019, 02:41 PM
Interesting, thanks for posting! I suspect that they are driving the first two stages of the if amp with a different level of agc (through the dc amplifier, v11) than the rf stage (direct from the local/distant switch) to optimize signal to noise ratio at a given total gain. This is just a WAG.
Old 02-11-2019, 04:50 PM
I haven't traced it through, but if what you surmise is the case, it's quite normal for TV AGC design.
This is called tuner AGC "delay." This doesn't mean a time delay, but that the tuner runs at full gain for weak signals so that the noise figure is maximized [EDIT: I meant minimized, of course]. The tuner AGC gain reduction starts only when the IF AGC gain reduction has already had some effect. In the low signal range (I seem to recall, typically below 1 millivolt RF) the IF AGC is active by itself. Then, above that level, AGC gain reduction is also applied in the tuner.
An alternative, which was never used in TVs as far as I know, is to run both the tuner and IF at max gain for as large a range as possible and use a PIN diode attenuator at the input to adjust signal level.
TVs actually get pretty poor noise figures when the signal is strong and tuner AGC is active, but as long as the video signal-to-noise ratio is great enough to make the noise invisible, it's OK.
Old 02-12-2019, 01:05 PM
The alignment is done.
Here is what the IF curve should look like.
Here is what the initial curve looked like. Notice that the curve looks good but it is "off" frequency.
Here are the individual points after alignment. Not perfect but pretty close.
Then some pics from this morning.
Old 02-12-2019, 01:11 PM
Great!
Old 02-12-2019, 02:02 PM
Gleb's Avatar
Gleb Gleb is offline
Good job!
What about the equipment you use for alignment? How do you insert the test signal, and couple the detector probe?
To understand a bygone era, you should use things from it
Old 02-12-2019, 02:27 PM
Titan1a Titan1a is offline
It looks better than new! Really great job!!!
Rick (Sparks) Ethridge
Old 02-12-2019, 02:31 PM
Originally Posted by Gleb View Post
Good job!
I use an EICO 369 Sweep generator, a BK 200D Signal generator, a Knight KG-625 VTVM, and a BK 2150 scope.
The EICO 369 probe have the Detector in it. I use the probes called out in the EICO manual.
Great!
Thanks.
Old 02-12-2019, 02:33 PM
Thank you.
