Old 02-12-2019, 06:59 PM
irext's Avatar
irext irext is offline
That chassis looks too nice to hide it away in the cabinet :-)
Nicest resto I've seen.
Old 02-15-2019, 12:41 PM
Originally Posted by Titan1a View Post
It looks better than new! Really great job!!!
It is better than new!
The component quality of today, it'll last a good long time
Everyone I knew, used to say I had a lot of patience, but nothing like yours. It's a work of art!
As said before, who would think a small player like Arvin could build a set of that caliber. Half of Arvin's production was in metal fabrication. They made the best portable electric heaters.
I understand, they're still in business making car parts and mufflers, Arvin Meritor.
Old 02-16-2019, 01:06 AM
Gleb's Avatar
Gleb Gleb is offline
It is better than new! The component quality of today...
That's true, but the sad thing is that there's almost nothing original left under the chassis... On the other hand, there's no choice, you have to do something with all that leaky capacitors and drifted resistors. BTW, are the original-looking Allen-Bradley resistors hard to find in usable quantities? As I guess, they remained in production until recently (up to the 80s or so)
To understand a bygone era, you should use things from it
Old 02-16-2019, 12:59 PM
I lived in Milwaukee, Wisconsin for 46 years, about a quarter mile from the large Allen-Bradley plant!
If the breeze was right, I could smell the resistor department aroma. They moved the resistor and small potentiometer department to Mexico sometime in the 70's or 80's.
Centralab did the same.
Old 02-16-2019, 02:31 PM
I've been able to find small stashes of 40's-60's carbon comp resistors...Even NOS they are drifty and moisture sensitive...I have to make sure they are in tolerance before using the NOS examples.
The classic ohmite Brown Devils are still in production (though they are being phased out gradually) and new ones look original...
They more modern styles are made in more original shades of brown and I eventually plan to make up a kit of those.
Old 02-17-2019, 03:28 AM
Gleb's Avatar
The classic ohmite Brown Devils are still in production and new ones look original...
That's a good idea, the newer resistors suppose to be much more stable and reliable while looking original.
Since I'm crazy on saving the initial under-chassis appearance, a set of the full E24 row of antique resistors has been my desire for a long time. I used every chance to get any quantity of the resistors, filling a special box little by little with them. When I collected a good amount of the resistors, I sorted them in the row and made a storage box to keep them in order:
Since we're lucky here in Russia to have carbon film types ('the green rods') since the 1940s and they are not very fail-prone, such a good source of the proper resistors promises me years of happy restoration life
Old 03-04-2019, 05:15 PM
OK, been away for a couple of weeks. Back on the project.
I added some 300 ohm twinax, cleaned up the tube shields, installed the control cover, added the cans and paper tubes to the E-Caps, and the CRT mount bracket. That should just about do it for the chassis. On to the CRT and cabinet.
Old 03-04-2019, 08:01 PM
electronjohn's Avatar
I like....big sparks!!
Just beautiful.
Ham shack...AM side: Knight-Kit T-60, RME-45
Vintage SSB side: National 200
Modern SSB: Kenwood TS-180S
MFJ tuner, 130' dipole
Old 03-18-2019, 11:30 AM
Cleaned up the CRT and then moved on to the cabinet.
The cabinet top and sides were made from fiberboard and then covered with a faux Mahogany finish. There must have been something heavy placed on top of this TV which remained for decades. The top was dished in quite a bit. The sides were affected too.
So I decided to redo the top and sides with 1/4 birch ply and new veneer. I've have pretty much finished the new plywood and need to do some detail on the existing mahogany trim. Then on to the veneer.
Old 03-18-2019, 04:59 PM
I don't even think that chassis looked as good back when it was built as it does now.
Old 03-21-2019, 09:39 PM
Thanks timmy!
Old 03-21-2019, 09:42 PM
Today I applied the new Ribbon Sapele Mahogany veneer to the cabinet. The veneer is the paperback variety and I used the iron on method to attach. All went well. Tomorrow I'll do the black grain filler.
Old 03-22-2019, 09:51 PM
Grain filled and stained.
Old 03-23-2019, 05:36 PM
I stained the inside and applied some Medium Red Mahogany to the cabinet. On to the seal coats.
Old 03-23-2019, 09:55 PM
irext's Avatar
That's going to be the nicest Arvin on the planet!
