Old 10-24-2019, 12:19 AM
ALTEC9846-8A's Avatar
ALTEC9846-8A ALTEC9846-8A is offline
canadian rca television model 16-t-11
Does anyone have a schematic for this. I have found some that are similar but mine has a distance/local switch where the tone control is normally located. I have worked on this for about a month. The vertical output transformer was burnt out and I need a new one.
ALTEC 9846-8A Studio Monitors YAQIN 100B TUBE AMP Sony TA2000F preamplifier
Old 10-24-2019, 05:21 PM
info found
I emailed the man I got the TV and he has the schematic and info on it. It's a rare 25 cycle model unique to Canada. I will continue my project. This explains all the problems I had finding the right info. Thanks Keith
Old 10-24-2019, 07:19 PM
The third picture clearly shows the vertical working. If your trans didn't burn after that picture it may be fine.
All those paper dielectric tubular ceramic shell caps are going to cook all your transformers if you keep running the set with those lousy caps.
Old 10-31-2019, 01:20 AM
Also Building on what Electronic M said here, your second picture showing a bright line in the middle of the screen, I hope you didn't run the TV for long that way, because that's a good way to ruin that picture tube because that line will get burned right into the picture tube and once you do that, the Picture tube is toast...
Old 11-13-2019, 02:06 AM
the vertical output transformer is the wrong one. Ran it to see if it would work but it didn't.
