Old 01-30-2020, 04:16 PM
what I've been up to: Stewart Warner Mirror in Lid
Probably over 5 years ago I bought a Stewart Warner Mirror in Lid set from Wiscojim. The set had the wrong knobs no front service control cover plate (but materials to reproduce it), chunk out of the back corner of the foot so bad I had to slip an 8-track cart under it to prevent it from falling over when stuff was stacked on top of it, and the 10FP4 had an open heater.
Since I was missing some stuff I shelved the project and waited for what I needed to become available. Back in early fall I bought a fairly complete set is similar condition from Tony P and that got the ball rolling.... admittedly I have other projects I rather do first, but space is severely limited to the point that I need to get rid of duplicate consoles/large sets as a priority. So I've been making one perfect set to keep and one fixer upper to sell.
I ended up refinishing the cabinet from Jim's set since there were fewer gouges in the wood and less veneer missing, took the main cabinet and combined it with the base/feet from the set that came from Tony...I also refinished and tried to use the lid from Tony's old set since the veneer pattern was nicer but it didn't fit the same as the one that matches the cabinet.
I ended up refinishing both lids. The second one is almost done I just need a warm day to give it a final coat of lacquer.
I was trying to achieve a near mirror finish but I believe it was cleaned with silicone oil based polish or something similar. The bare wood had sections the top coat refused to stick to until a coat of shellac was applied to stop the issue... figuring that out wasted a LOT of lacquer and most days warm enough to spray... between that and the lacquer smooshing out from under the clamp I used when gluing back in the top rear crossmember/hinge mounting, I'm going to have to revisit the sides when it warms up outside....color is consistent but surface issues need to be sorted.
Chassis resto wasn't too bad. Caps are packed pretty tight in this set so better than half the job felt like brain surgery and another quarter of the caps had to be done in a sequence to minimize hastle of replacement. The set uses 2 pairs of 200uF IIRC 150V lytics in parallel to make 2 400uF caps which I replaced with a pair of 470uF caps I had saved from an old computer PS (never thought I'd use them in a tube TV!). After recap and changing the seleniums I went to power it. This set is a series heater set, but there was a transformer version too. On the ETF Sam's covers the series set and riders covers the transformer set. On power up the only the IF heaters lit and much too bright...I gradually realized most of the parallel heater tubes had been swapped for their 6V versions, and some were totally wrong...the worst of which was the ballast had a 6SN7 in it's socket...the heater was somehow bridging the IF heater pins of the ballast. I think this may be what killed the CRT heater. stealing every tube from the other chassis I finally got it to run on the variac... the separate RF based HV system warmmed up first which gave me some screen burn worry till sweep gradually started up. The tuner seems to be the same slug tuned design as a Raytheon porthole I own, and someone messed up all the fine tuning screw adjustments so I dialed in the ones I needed and ball parked the rest.
I still need to figure out how to change the mirror as the rear silvering is kinda lousy.
There are some interesting differences between the two sets. There were probably a number of production changes in this models life. The two sets have different lid size/mounting holes and hardware (also early one has black metal lip holding mirror later one is maroon red), the base screw locations are different and the base dimensions are slightly different (I was able to transplant the base sufficiently well), the veneer is different thickness between the two, and Tony's (IMO later production set) has the mount bolt heads for the CRT hidden instead of protruding through the face next to the CRT mask. Part of me wishes I knew which tuning knob Jim's set originally had since I have seen an earlier looking set of knobs on one of these sets that was on eBay years ago...
The chassis also have 2 notable differences (I haven't pulled the newer one ) the later set has a coil can mounted below the back of the chassis (which is the bottom on a mirror in Lid set) in such a way that removing the speaker is tricky. The plug in selenium Rectifier module is on the main chassis on the later set but on a separate sub chassis with extension cable (mounted to the side of the cabinet) on the early set. The early set has provisions for the selenium to mount to chassis the same as the later one.
Once I finish the keeper I plan to assemble the unused parts into a restorable set for some one else to tackle.
Here are a couple of pictures.
Old 01-30-2020, 04:44 PM
WISCOJIM WISCOJIM is offline
Glad to hear you've made some progress on that one!
I remember first bringing that to the WARCI TV swap meet in July of 2014. I can't believe how many TVs I brought to that meet now that I look back at some of the pictures. I even set up shelves for many of them. My back must have been feeling okay back then.
The pictures from the 2014 WARCI TV-radio swap meet: http://warci.org/july-20th-2014-meeting-photos/
The story of the meet: http://www.videokarma.org/showthread.php?t=261482
Old 01-30-2020, 05:04 PM
Same here.
There was a point where I was close to selling it since I had been looking for some parts for years, and I was kinda sick of the over year long hit and run attempts at scheduling pick up of the second one and wanted an excuse to end that email chain.
Between getting the second set to fill in the missing parts, and my sluggish attempts to teach my self refinishing over the last year it is on a trajectory for being much nicer than I would have expected to make it when I bought it... though how good my refinish ends up is still up in the air.
Old 01-31-2020, 01:20 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
You kids and your chinese cartoons...
Old 01-31-2020, 06:11 AM
says the person with the MLP avatar! :P
https://www.youtube.com/watch?v=j1x2vBLt8J0
Old 01-31-2020, 03:23 PM
TonyP TonyP is offline
I dont think the mirror on mine is original. I repainted the mirror rails. I repainted them maroon because it was the closest i could find at the hardware store. I really think it was more a red brown originally. There is a strip of wood screwed down at the hinge end of the lid if you remove, you can slide the mirror out. I am going to assume there was some kind of rubber gasket. When i found it it was puttied in with window glazing. I tried to get putty between the glass and rails and gave up. Also couldnt find any stock rubber glass gaskets that fit. A refinshing trick i heard, but never tried was that silicone will only stick to silicone. So if you think you have a piece contaminated with silicone, put a couple drops of silicone in the finish. Ive never tried it so maybe you might want to try that on some scrap first.
Old 02-02-2020, 04:33 PM
nasadowsk's Avatar
Damn does run fast…
Don't those sets have a weird horizontal section?
Old 03-03-2020, 04:49 PM
I finally finished the lid and got it all back together. I'm very happy with the color match. The underside of the lid and the control face board are still original finish and the top and sides are so good of a match that I can't tell the difference.
There are a couple imperfections and issues in the finish, but it is plenty good to live with indefinitely in my book. I also need to tweak the vertical linearity control on the bottom of the chassis and centering...I had it set good on the bench but the yoke is in a different position now that it is in the cabinet and been moved 2 flights upstairs.
Old 03-03-2020, 04:52 PM
That sure looks a lot better now!
Old 03-03-2020, 07:41 PM
The picture in that third shot looks a little snowy -- oh, wait!
Beautiful resto!
Old 03-04-2020, 12:06 AM
It looks like it turned out real nice, at least from back where I'm standing.
Old 03-04-2020, 05:37 AM
kvflyer kvflyer is offline
Beautiful resto!
Looks nice! And I was not quick enough to make the comment about the snow!
Congratulations.
Old 03-04-2020, 08:52 AM
Thanks. It was 51 on Sunday which made it just warm enough to lay down the final coat of lacquer on top.
Old 03-05-2020, 06:46 PM
Its a lot further along than when i had it.
