Old 02-09-2020, 04:12 PM
JohnCT's Avatar
JohnCT JohnCT is offline
Oops, mixed up a couple of tubes, my 6BK4 is very heavy leaded glass, the rubberized lead tube is a 3DR3 rectifer.
Yep, that's the one. I have at least one and maybe a couple of more. I've got a thousand tubes I haven't catalogued in my basement.
Off topic, but I discovered I've got a small RCA scope and a Kingston "Absorption Analyzer" whatever that is. Looks like a scope (has a CRT) but isn't.
John
Old 02-09-2020, 04:29 PM
Originally Posted by Tom9589 View Post
I'm going to repeat an urban legend here (which means it may or may not be true).
I heard the x-ray problem was due to GE not wanting to pay RCA royalties for using the 6BK4 and came out with their own shunt regulator which generated the x-rays. The story goes that a woman had a cat that liked to sleep under the warm console TV when it was on. The cat started losing hair and the source of the problem was then discovered. I do know that GE replaced a lot of their first generation shunt regulator tubes as a part of a recall.
Knowing GE it probably was a matter of them not wanting to add $0.10 worth of shielding metal for the shunt reg/HV rect.
Old 02-09-2020, 06:09 PM
Originally Posted by mr_rye89 View Post
My kid brother keeps saying I should make a Radiation King badge for one of my vintage TVs
Do you have a picture of this set?
Radiation King was a fictional brand, but someone on VK had the same idea and made this some time back...I thought it was interesting and downloaded it, today I stumbled on it, thus this post.
Old 02-09-2020, 06:37 PM
This really happened to my parents cat, but in this case (mid 60s Sylvania set) the cat slept on the top at the left side, which was the warmest spot, right above the horizontal and hv section. The 6BK4 was replaced with a leaded version, Cindy recovered and lived to a fairly old age (14 or 15 years).
Old 02-09-2020, 08:42 PM
JohnCT's Avatar
LOL, LOVE IT!!
If I end up buying that Air King I'm going to have to cast a new name plate.
John
Old 02-09-2020, 08:49 PM
The problem came about due to faulty manufacturing in which the tube elements were not properly aligned. If all the elements were straight and concentric, the X-rays generated by the anode were blocked by the lower tube elements, but if mis-aligned, the tilted elements would allow some X-rays to escape around the edges.
