Old 12-05-2020, 12:38 PM
Dave Tilotta's Avatar
Dave Tilotta Dave Tilotta is offline
Broken shaft on a Motorola TS-4
Hello,
Is this tuner shaft repairable on my TS-4? One half of the aluminum split shaft is broken and the piece is missing -- the set was given to me this way. I'd love to find a way to repair it, if possible, or at least find some way to attach the knob so that I can tune the set.
Thanks.
Dave
Old 12-05-2020, 01:14 PM
init4fun's Avatar
init4fun init4fun is offline
Originally Posted by Dave Tilotta View Post
Hello,
Thanks.
Dave
Hi Dave ,
When I saw your post it brought to mind that there are kits sold to extend a potentiometer's shaft that consist of a coupling to join two shafts , and a piece of shaft to be cut to the desired length . This setup could be used of course to provide a new shaft end to your tuner , the enclosed pic is one such setup I found on Amazon by searching "Oscilloscope control shaft extender" . (I searched oscilloscope because I remember seeing all kinds of shaft extenders in the old vacuum tube scopes)
Old 12-05-2020, 01:26 PM
Originally Posted by init4fun View Post
Hi Dave ,
That's an excellent idea! I searched for your terms on Amazon, however, and couldn't find what you did. Could you double-check?
Dave
Old 12-05-2020, 01:37 PM
This?
https://www.amazon.com/FidgetKute-Ex.../dp/B0812TMJ6R
init4fun's Avatar
If this link works , this is what I saw
Old 12-05-2020, 01:38 PM
init4fun's Avatar
Wow , we posted it at the exact same time !
Old 12-05-2020, 01:53 PM
Thanks, perfect!
Dave
Old 12-06-2020, 07:20 AM
Polaraligned's Avatar
Polaraligned Polaraligned is offline
$25 for that thing? Yikes. Maybe you can cut the end off of an old pot and use a 1/4" coupler.
Old 12-06-2020, 10:39 AM
That's also an excellent idea!
On a related note, could someone describe the details of the channel knob for this early set? I'm not sure what it looks like. The volume and contrast knobs for the split shafts, which I have, are similar to the reproductions sold at renovatedradios but they're plain without the inscribed gold circles. Since the channel selector shaft is also split, and since there is no fine tuning control on this set, I'm guessing that the knob resembles the volume and contrast knobs but with a simple gold dot to indicate the channel. Is this correct?
Dave
Old 12-06-2020, 07:53 PM
As I recall the tuner knob on the models without fine tuning are identical to the other knobs but with a dot or mark to indicate position. I have one somewhere, I'll take a pic if I find it.
Found it. To think, someone back in 1948 must have had the job of poking a soldering iron in these knobs to make the dot.
Old 12-06-2020, 07:58 PM
Dave
I believe that is correct for the early production chassis. The early ones have some of the 6KV caps mounted above chassis, channel 1 and no fine tuning.
Later chassis usually have a smaller center shaft for fine-tuning that rotates a single capacitor plate on the back of the channel water switch.
Old 12-07-2020, 07:50 AM
Thanks. Is it ribbed for a split shaft?
Also, my volume and contrast knobs don't have concentric circles like yours does. Are mine not original? I appended a photo of mine at the bottom of this reply.
Yes, two of the 6KV caps are mounted above the chassis -- they're 0.03 mfd which surprised me. My set also has channel 1 and no fine tuning.
Old 12-07-2020, 02:03 PM
Yes, split shaft. No, those aren't the correct knobs for the Motorola, they had rings, and were red or tan to match the cabinet.
Old 12-08-2020, 07:36 AM
Thanks. I guess I need to find some original knobs, then.
Old 12-09-2020, 09:00 AM
kvflyer kvflyer is offline
Reproductions are available from this vendor.
http://renovatedradios.com/product.php?product=248
