Old 01-29-2021, 05:21 PM
JOJCANADA's Avatar
JOJCANADA JOJCANADA is offline
Early 1960s Sears silvertone black and white tv repair
I got this set out of a shed a few years back but my knowledge of tv repair is shaky at best so I didn’t mess with it to much. What I did notice was that the fly back transformer definitely had some issues as you will see in the following pictures. I was also unable to find any sort of documentation or mention online, save for one picture that shows it. If anyone has any help or knowledge in regards to my next steps please feel free to post.
Old 01-29-2021, 05:26 PM
JOJCANADA's Avatar
Some pictures of the set and internals
The following are some pictures of the set
Old 01-29-2021, 05:50 PM
JOJCANADA's Avatar
Further pictures
Here are a few more pictures
File Type: jpg 99D6C408-3EF3-42C2-BB73-5047C334B497.jpg (87.4 KB, 24 views)
File Type: jpg 1A74826A-A081-47CF-B074-ED5D2BAC81D6.jpg (63.0 KB, 30 views)
File Type: jpg 0EEDB28F-05E2-47DF-849C-1966E3ECC215.jpg (100.3 KB, 37 views)
Old 01-30-2021, 10:01 AM
The red wire in your hand looks like its the HV lead to the CRT. Its
pulled out of the white plastic HV "cup".
Probably broke off the HV rectifier socket. You will need to take apart
the HV cup to see.
Interesting to see the US$$ v Can $$ in the ad. The color set would be $300
& your B&W abt $140 US$.
Old 01-30-2021, 05:42 PM
JOJCANADA's Avatar
Thanks for the response
I have taken a closer look at the set and especially the area you mentioned, the high voltage cap. Here is what i found, I also need a new 17BE3 damper tube as mine has gone to air.
File Type: jpg AA5742CD-83A6-4921-8677-4606910FFB67.jpg (61.9 KB, 37 views)
Old 01-31-2021, 08:47 AM
There should be a big long model number on the back. Format
is ###.########
Post that & maybe I have a manual for it. If it has a 4 digit model number
that probably wont help.
Zeno
Old 01-31-2021, 02:25 PM
JOJCANADA's Avatar
Here is what I found
Here is the number on the back, hopefully a schematic can be obtained from this information as I have been unsuccessful finding one myself.
File Type: jpg 4FFA891B-953E-4827-8D72-6D6DFF97F5A0.jpg (78.3 KB, 31 views)
Old 02-01-2021, 12:43 PM
DavGoodlin's Avatar
Motorola Minion
I hope someone has a Simpson-Sears directory for those numbers. That TV was made either by Toshiba or Sanyo but the numbers don't cross to anything sold via Sears of Chicago.
Simple parts in them either way, so it is certainly worth the effort.
Based on Sears and Roebuck, the Sams Photofact index lists the numbers as 528.xxxxx for Warwick sets and 562.xxxxx and 564.xxxxx, 456.xxxxx for the Japanese manufacturers
-Dave G
Old 02-01-2021, 06:06 PM
JOJCANADA's Avatar
Sears tv identification
It is a Canadian set I believe
As for the repairs it has no high voltage and the damper tube is bad, probably also needs a recap. Not sure of the crt as I don’t have a tester. Other than that I’m open to any and all comments.
Old 02-01-2021, 06:27 PM
fixmeplease fixmeplease is offline
What are the other numbers shown above what I think is the schematic on the flyback cage?
It could be fixed without a schematic if the parts are labeled or have colorings for size, but a few vital parts would need the schematic for cross reference.
Old 02-02-2021, 09:28 AM
JOJCANADA's Avatar
Here is a better picture, it shows some of the tubes but it is quite worn.
File Type: jpg 45025A33-8CEC-4528-B489-470687F61ECC.jpg (91.7 KB, 35 views)
Old 02-08-2021, 11:26 AM
JOJCANADA's Avatar
17be3
does anyone have one? mine is bad. also if anyone has a schematic post it,
thanks again.
Old 02-09-2021, 03:12 PM
AlanInSitges's Avatar
Three bucks on tubedepot: https://tubedepot.com/products/17be3-17bz3
You'll have to find a better model number (or chassis number) if you want a schematic. The one displayed on the back cover doesn't cross to anything.
Old 03-28-2021, 03:33 AM
ronl ronl is offline
Hi Jojcanda.did you ever find service info for that set? I offer free scans of vintage Canadian TVs on this site.I have a mostly complete RCC set of Canadian service info.
Old 03-30-2021, 11:03 AM
JOJCANADA's Avatar
As of yet I have not, so I would be very appreciative if you have the info for my set. I posted all serial numbers in previous posts on this thread so if you find any matches please send them my way.
Thanks
