#46
Will do. ! Thanks Cheers |
#47
Caution! I believe the CRT except for cathode and G1 are all floating on the high voltage (thousands? of volts).
If you have a spare replacement .005 cap for C54/C55, that could work to protect your scope, as it has the required voltage rating for whatever is on the CRT. |
#48
A similar Admiral schematic
https://www.earlytelevision.org/pdf/..._rider_tv3.pdf lists C54/c55 as .005 mfd, 6000 volts. |
