Old 08-05-2021, 01:48 PM
elara elara is offline
Help to recognize this element.
Please some help to recognize this electronic element.
I would like to find a replacement exactly the same, but I don't know how to interpret the code that is printed on it.
The element has printed 4D-123 51M on it and was pulled out from the input filter in the primary stage of a VWR1200-D switching power supply board in a Pioneer CLD-99 laserdisc. This element is L1 in layout of board.
Distance between pins is 10,5 mm x 13 mm. Core length is 20 mm.
I am not a technician and this is all the information I have about.
Thanks you very much in advance.
Old 08-05-2021, 02:05 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
What's wrong with it other than some old factory glue?
Old 08-05-2021, 10:45 PM
Hello, unfortunately that is not glue, this is melted plastic. This unit suffered an overheating caused by a short circuit in the switching power board.
Thanks.
Old 08-07-2021, 09:57 AM
Notimetolooz's Avatar
That is called a common mode line choke.
The inductance and resistance is not critical.
You might find a close enough match here.
https://www.digikey.com/en/products/...MaT6GfibiYmJAA
The power supply fuse should have blown to prevent this happening. Also more components on the power supply are probably bad now, like the input rectifier and switching transistor(s).
Old 08-07-2021, 10:55 AM
Ed in Tx's Avatar
Originally Posted by Notimetolooz View Post
The power supply fuse should have blown to prevent this happening...
Yeah.. be sure to remove the piece of foil wrapped around the old fuse before you plug it in again.
Picture of the melted plastic looked just like the rubber foamy glue garbage the mfgs used to use on boards and components.
Old 08-08-2021, 06:12 AM
Doug Doug is offline
https://www.goldmine-elec-products.c...?number=G24152
Its two seperate coils .so if the coils still have continuity ,work on the power supply problem ,if one is open then you
Should replace it. Do not put in an oversize fuse.
Old 08-10-2021, 12:19 PM
I don't know about new, but there are so many that look alike in VCR's and DVD players . That one should still work if you can read about 2 or 3 ohm through each coil and there's a readind the same on the other coil.
