Old 12-18-2021, 10:59 AM
fixmeplease fixmeplease is offline
1973 Pickup Radio Stuck Tuner
Im unsure anyone will know the answer. i have a 1973 Ford pickup AM radio and I cant move the tuning shaft. There are plastic gears so Im not wanting to force anything. Where would this be stuck? The shaft? The gear? And what do I use to loosen it? Ive never worked on an auto radio before so its new to me. See pics for what Im dealing with. Thanks!
Old 12-18-2021, 02:37 PM
It's probably metal to metal corrosion sticking it. I think if you remove the C clip on the shaft of the big gear you can separate the 2 gears to safely check which shaft(s) are stuck.
If it's metal to metal corrosion or petrified grease a penetrating oil like PBlaster should be able to unstick it.
Old 12-18-2021, 04:56 PM
Thanks! I'll take a look at it in the next day or two and get back. Its not a rush thing, I just dont want to break it.
Old 12-21-2021, 09:26 PM
It ended out I didnt need to remove any clips. I loosened the nut on the outside of the radio (on the shaft) and that must have taken the pressure off of it as it turned then but hard. Then I just kept adding 3 in 1 oil into end of shaft while I turned it back and forth. So its all fixed, the shaft anyway. Thank you again for your help.
