#136
I would of thought an electrostatic deflected CRT would be more susceptible to high voltage ripple vs magnetic field, although I get that one can be related to other.
#137
It's very noticeable - especially the vertical stretching. It's like a bulge slowly moving up through the image.
Sure, if I'm just going to demonstrate this set, it's no big deal. At this point I'm more curious than anything and hoping to increase my troubleshooting skills. |
#138
OK, the little filament transformer definitely has an effect. If I unmount and move around it both effects the CRT image and hum coming out of the speaker. Will continue experimenting...
#139
I've seen a lot of instruments which contain electrostatic deflected CRTS with MuMetal shields over the electron gun assembly. The typical deflection angle of an electrostatic CRT is very small compared to a magnetically deflected CRT so any stray magnetic field would have a more pronounced effect on an electrostatic CRT.
For a quick test, disconnect the tuner filament transformer and get a 6V lantern battery to power the tuner's filaments. See if the picture twerking and audio hum go away. |
#140
#141
#142
Aw man. Now we're not going to know what fixed it.
#143
Yeah, and there's no reason to think it won't come back. Could be a chassis rivet not making good contact, a cold solder joint, intermittent tube short...
#144
Time for some wiggling and tapping of things.
#145
Bob, how is the audio hum now?
#146
I eliminated it by redesigning the 1st audio amp.
#147
It looks pretty good, considering it probably never played that good when it came from the factory. LOL.
RCA VICTOR and its dealers bring you...... |
#148
Dang Dude! Seldom see linearity that good on electromagnetic-deflection sets.
#149
Not so fast
Distortion problem is back and a new issue has cropped up. I used to get good focus in the middle of the control but now I need to have it full clockwise. The HV box is power in a rather odd way that makes me think the two problems are related. |
#150
You sure that's not Rosemary's Television you have there?!
