Old 02-23-2022, 01:19 PM
Originally Posted by probnot View Post
Hmm that sounds shorted. On the diode setting, the two ~(AC) pins should measure open (both directions).
For the DC side (+ and -) you should see close to 1.0v but only in one direction.
That's what I thought. There's a number on the bridge rectifier, I think I might have something in my parts stash that might work, (I had found a couple of baskets at the local SA a couple of years ago that were full of NOS TV and VCR parts like IC chips, capacitors, resistors, diodes, fuses, rectifiers, rectifier bridges etc. that came from a local appliance store that went out of business.)
Old 03-01-2022, 10:09 AM
The Bridge Rectifier in my VCR that was bad is a S1WB S40 Rectifier Bridge, at least that's the numbers on the top of the rectifier bridge which when I look that number up on google, nothing shows up...
See picture below.
File Type: jpg GE (Panasonic) VCR Bridge Rectifier.jpg (40.8 KB, 11 views)
Old 03-01-2022, 12:03 PM
40 71 could be just a date code for 40th week of 1971, if that fits the date of manufacture of the VCR.
Edit: although that seems very early.
Old 03-01-2022, 12:38 PM
That seems a bit too early for a date code, unless Panasonic was using up old parts when making their VCRs, because this VCR is from 1987...
Old 03-01-2022, 03:19 PM
Yeah, on second thought, not likely.
Old 03-01-2022, 04:41 PM
If it follows the numbering scheme used on this example, the last two digits are a date code (perhaps the first month of 1987 ?)
https://www.mouser.com/datasheet/2/3...BA-1202965.pdf
Perhaps the 40 indicates 400 volt?
just a WAG,
Old 03-01-2022, 05:50 PM
just a WAG,
Well I ordered some diodes from mouser that had similar specs to the original rectifier bridge (which I did find a spec sheet for an S40 type S1WB rectifier bridge), so we'll see what happens when it gets here, I had also replaced one of the main filter caps (the 4.7 uF 200 VDC filter cap) that tested bad (had extremely high ESR value of 15k ohms.)
Old 03-03-2022, 04:11 PM
UPDATE: Replaced the bridge rectifier and the VCR is still blowing fuses, so I wonder if maybe the Q1 is bad in the power supply board (the transistor on the heatsink.) when I did the diode test it seemed like it checked fine, but maybe I wasn't doing the check correctly.
What would the correct replacement for that transistor be? I looked up that transistor (it was a Panasonic part number) and it didn't seem to cross-reference to anything currently being made (no NTE parts or anything.)
Old 03-03-2022, 10:07 PM
starbond starbond is offline
If its anything like my unit, the heatsink transistor was bad after the fuse kept blowing. my mistake was not using a dim bulb tester the first time around, so I had to buy the replacement transistor TWICE. Luckily there was some NOS on ebay.
Yours has no C or B value on it?
Old 03-03-2022, 10:28 PM
I'm guessing you're right that that heat sunk transistor is bad on my VCR, it did have a code on it, but I can't remember what it was now, and I made the mistake of putting the power supply back into the VCR.
I'll take a look in the morning.
Old 03-16-2022, 01:14 PM
djfivos djfivos is offline
Hello. That looks like a rebadged Panasonic PV-4750. The 4760 is the hi-fi stereo version. Be sure to check the electrolytic caps in the power supply before using the machine.
File Type: jpg Screenshot 2022-03-16 at 8.16.25 PM.jpg (25.8 KB, 12 views)
Old 03-16-2022, 01:19 PM
If this is the power supply your machine has, I can post the full schematic if you need it.
Fivos
File Type: jpg Screenshot 2022-03-16 at 8.17.58 PM.jpg (122.4 KB, 13 views)
Old 03-16-2022, 08:37 PM
Fivos
yep that's it right there, I still need to check the switching transistor in the power supply (Q1) because this power supply only has 2 transistors in it overall and the one of them is the Switching Transistor (the transistor attached to the heatsink) that's the only part I haven't changed yet that I suspect might be still causing the VCR to blow fuses.
Old 03-17-2022, 06:44 AM
Did you disconnect Q1 from the circuit and measure it? Are the zener diodes OK?
Old 03-17-2022, 09:54 AM
Yes, all the diodes checked fine yet. The only diodes that checked bad was the bridge rectifier, which I already changed that out for a modern replacement the switching transistor I have not had a chance to check yet, the way they did the power supply in this VCR is that you have to disconnect a ribbon cable that's connected in a strange manner and then undo 2 solder blobs holding it to the main circuit board and then bend a retaining tab and then gently remove it from the main board without cracking the main board.
