Old 11-07-2022, 12:42 PM
jayjaydub jayjaydub is offline
Sony KV8000.
Hi folks, newbie here. I have this nice little portable TV that was working 100%. Until it wasn't. It is totally dead, no video, no sound. The pilot light doesn't light up. I have checked both fuses and the on/off switch, all good. There is voltage leaving the secondary of the power transformer. My skills do not extend to diagnosis at the component level on the boards- nor do I have much in the way of test equipment. I don't have a schematic, either. I don't have the accessory battery pack for this set, so can't tell if the fault is in the AC or DC power supplies. Anyone got suggestions as to what I can do? I hate to bin it, but at the moment it's a doorstop.
Old 11-07-2022, 02:08 PM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to all,
Hi Jayjaydub,
Cute! little 8" Trinitron, end of 1970s.
You're in luck! the full Sony KV-8000 service manual is downloadable for free on ElektroTanya, BTW once of the best worldwide sources for service data :
https://elektrotanya.com/sony_kv-800.../download.html
Please state your skill level in repairing vintage electronics so that we can help you.
Do you have a Volt/Ohm/Ampmeter; digital? analog?
If AC volts on transformer secondary, probably a shorted rectifier and dry/shorted filter Caps.
Once you have the Service Manual, see if there is +22V DC at the output of the main regulator board (Q901 power transistor).
See block diagram below.
The Pilot light is a miniature Neon tube powered by a voltage derived from the Horizontal power Scan section.
Keep us informed....
Best Regards
jhalphen
Paris/France
File Type: jpg C6CE56FD-3272-4607-A20D-65DDA72C98F9.jpg (65.0 KB, 11 views)
Old 11-07-2022, 03:42 PM
Popester's Avatar
Popester Popester is offline
Sony’s we’re common to have the high voltage block arc and crap out. Look for carbon arc tracking. The HV block we’re usually red epoxy and had the hv lead out of it go to the anode of the picture tube. Sony was well known for using derived voltages to power other parts of the set from the flyback i. e. sound video color circuitry. That’s at least a start. Use your nose to see if anything smells burnt and good luck.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 11-08-2022, 08:15 AM
Find Q901
Its chassis mount near the power cord.
All 3 terminals should have APX 22 VDC on them.
While there if the power socket is mounted on a PCB check it
for cold solder joints.
Report back.....
Old 11-08-2022, 08:26 AM
Btw
BTW this set uses a hoz design most will never see.
Output # 1 runs the HV & scan supplies.
Output # 2 runs the hoz sweep & pin
Sony & Panasonic both did it. Maybe others.
Zeno
Old 11-08-2022, 08:34 AM
jhalphen's Avatar
Hi to all,
additional data from the Service Manual :
- Physical location of Q901 (red circle)
Best Regards
jhalphen
Paris/France
File Type: jpeg 8C8BFF50-95A8-4196-BCAE-433BEA4E165A.jpeg (134.0 KB, 13 views)
Old 11-08-2022, 03:52 PM
Sony KV8000
Find Q901
Report back.....
No sign of dry joints. I have 22v B-G, 22v C-E, 22v C-Ground. Does this sound like the transistor (D476A) is faulty?
Old 11-09-2022, 08:37 AM
Well done power supply is running.
Now check volts on
Q502 - C
Q503 - C
d504 - Cathode
d505 - Cathode
Probably all on the main PCB
Check the main PCB for bad joints especially on T502
That will narrow it to a stage.
Zeno
Old 11-09-2022, 06:31 PM
Sony KV8000 (cont)
No volts on any of these. In fact, can't find any power on the main PCB except the outputs from the power transformer. I guess that this is a clue! Whatever supplies/distributes power on the board is AWOL.
Old 11-11-2022, 09:46 AM
The 22 V from Q901-E is the main B+ for the hoz out Q503.
Only thing between the 22V & the FBT is R631
If that opened Q503 may be shorted.
