Old 03-24-2023, 11:11 AM
That screen is indicative of the horizontal oscillator being WAY off frequency, L22 tweaked way too far, or something wrong in that area? For some reason it's not at 15.734 kHz -15.625 kHz where it should be.
Old 03-24-2023, 11:35 AM
IIRC these sets have a coarse horizontal frequency pot hidden inside the hollow horizontal hold pot shaft. Just need a small flat edge screwdriver long enough to reach it.
Old 03-24-2023, 02:39 PM
Chris K Chris K is offline
It looks like L22 was off by quite a bit. I have a picture now albeit a poor one. It's a YouTube recording of an old CNN video that in itself, isn't great quality but the picture fed out of my RF modulator is a bit snowy and not sharp. The modulator works fine as a source on other TVs. Is this an IF section issue?...maybe weak tubes?? All original tubes in it because they all tested good.
Old 03-24-2023, 02:41 PM
And I have no idea why photos that I'm posting the same way as I did when they were in the correct orientation are now posting 90 degrees counterclockwise.
Old 03-25-2023, 07:53 AM
kvflyer kvflyer is offline
Cell phone picture? It happens all of the time. You can use something like MS Paint or Adobe Photoshop to rotate the picture, save it and then post it. The orientation is embedded in the picture.
Old 03-25-2023, 11:24 AM
Stinky Work
Old 03-25-2023, 01:18 PM
Final Stretch
Old 03-25-2023, 02:06 PM
As good as it's gonna get
Old 03-25-2023, 03:40 PM
init4fun's Avatar
init4fun init4fun is offline
Very good work Chris, that looks awesome
Old 03-25-2023, 04:19 PM
Thank You!!
Old 03-25-2023, 06:18 PM
Hi all...the picture is mostly good now. Contrast and focus are good. I can tell it's sharp because I can read small computer print on it just fine but...the picture is snowy...almost like it's not getting enough RF signal strength. I changed the tubes in the IF section and in the tuner to NOS but no change in fact, all of the tubes in the set have been replaced with NOS. I haven't done a thing to either the tuner or the IF circuit board. Any suggestions on a strategy to run this down?
Old 03-25-2023, 09:26 PM
Have you double checked for a broken antenna connection?
Old 03-25-2023, 09:49 PM
Does the local/distance switch have an effect?
Old 03-25-2023, 11:13 PM
Antenna connection is good and there is a difference between local and distance images. Not in the shop right now but the top setting was better. Still didn’t get rid of the “showiness” but it was better.
Old 03-26-2023, 06:00 PM
Is there a balun (matching) coil at the tuner's input? Those frequently got popped by a nearby lightning strike.
