Old 04-24-2023, 08:17 AM
Chris K Chris K is offline
Hey Chris the ballast you made is that design for this ts-4h ?
Yes...If you look back in the thread, I made it as per a discussion with Bob A. It's the same construction as the other ballast found in these sets but required a change in pin to work correctly. I'm pretty confident it was built correctly as I had many exchanges with Bob and other members in the thread.
Thanks
Old 04-24-2023, 08:19 AM
This is my current design using diodes. Compact enough to fit in the original metal tube.
Andersen[/url], on Flickr
This is the start of that part of the thread on page 3
Old 04-24-2023, 10:34 AM
All TS-4 versions prior to TS-4J use the 17A470303 ballast. It has an extra resistor only used in the very early revisions (prior to the TS-4H).
The other difference the is that the AC line in goes to pin 5.
It is connected to pin 6 in the later version of the ballast which is what you created.
So, you need to move the wore from pin 5 to pin 6 on the ballast tube socket. OR modify the ballast so the CL-90 goes to pin 5 instead of 6.
Old 04-24-2023, 12:10 PM
Ok just checking didn’t want to have to chase another problem. Then ballast ruled out, good, lol
Old 04-24-2023, 12:23 PM
The cage for the ballast can be easily removed just by prying it up a bit...if you want to check the work. It doesn't matter to me.
Old 04-24-2023, 01:59 PM
No I won’t check the work on the ballast but I’ll tell you that ballast gets HOT when running for alittle while to the point of not able to touch it. I thought this design is supposed to run cool.
Old 04-24-2023, 02:21 PM
Hot and cool are relative terms. It should be much cooler than the original, but it does generate heat. A thermistor has to get warm to work properly. That's why I put it on top.
Total dissipation for the unit is something like 8W versus 25W for the original.
Old 04-24-2023, 02:48 PM
Has anyone made this measurement yet? "Should be around 11.5K between pin 6 of the video amp tube and B++ (pin 4 of the ballast tube)"
There are just two resistors between B++ and the video amp plate. If there's no voltage on the plate, problem has to be here.
Old 04-24-2023, 03:08 PM
Ok here’s where I’m at got video but it appears that vertical is collapsing when I got video the vertical didn’t last long a heard a snap but Don’t know where it came from then trying to adjust will give me a horizontal line but adjusting back down it will stay so there’s something going on in vertical and it looks like whatever is going on it’s creating noise on the video signal.
Old 04-24-2023, 03:17 PM
I’m trying to post pictures but it’s not letting me saying the pics are to large and resized them smaller and still won’t pos pics.
Old 04-24-2023, 04:22 PM
Trying again
File Type: jpeg AA91F7FE-5845-46D2-89CE-36770DF9D234.jpeg (24.7 KB, 12 views)
File Type: jpeg 18CEB44A-8430-4F21-8DD6-D6E415F4122F.jpeg (22.2 KB, 11 views)
Old 04-24-2023, 05:17 PM
For his next Miracle...
Tim will part the Red Sea...and I understand he has located Jimmy Hoffa's remains!
Old 04-24-2023, 05:32 PM
I don’t know what’s going on with this site now I can’t click on a post let alone post a pic.
Old 04-24-2023, 05:38 PM
All I can suggest are the usual computer glasses of cold water in the face solutions with ramping up the size of the cup! Close out site...close browser...or reboot!
Old 04-24-2023, 05:39 PM
Did that already never had this problem befor.
