Old 06-07-2023, 04:59 PM
pac.attack76's Avatar
Stuck in the past
1983 Samsung Celebrity K20 chassis has vertical shrinkage
Set starts up normal. After warm up, it starts shrinking. I'm guessing caps in the vertical section. Should I start with those?
Genesis does what Nintendon't
Old 06-07-2023, 08:18 PM
damen's Avatar
damen damen is offline
Resolder the vertical IC, or output transistors first, then replace caps.
Old 06-07-2023, 08:23 PM
Stuck in the past
Ok, will do. It might be loose because tapping on it corrects it temporarily.
Old 06-08-2023, 08:24 AM
DITTO that will fix 95% of vert problems.
Old 06-08-2023, 08:55 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Yep, most likely bad solder on the transistors/IC due to heat and age. On old solder particularly, it's helpful to add some flux to the crusty joints, flood with fresh solder, then wick all the old solder off. Clean the board, add a bit more flux, resolder transistors/IC, then clean the flux.
John
