Old 05-23-2024, 08:03 PM
Aperna1985 Aperna1985 is offline
Is this right for a BK 1077B
Hey guys I replaced a few of the caps in my BK 1077b and after adjusting the vertical a little bit I was able to fill most of the screen. Do these usually fill up real nice or is there usually gaps like I have in my picture? If not I can't find a good schematic for the 1077b I find plenty for the 1077 and judging by the fact that the filters are different I don't know if I can go by the rest. What caps should I go after to get full vertical deflection?
Old 05-23-2024, 08:50 PM
There should be gaps. Do you have any of the test pattern sldies for it? The raster should be the same size as the slide, with a 4x3 aspect ratio. You have the height turned up too much.
Old 05-23-2024, 09:59 PM
I do have some slides, should it be just wider than the slide? I'm hoping to get some BNC connectors so I can try and make cables tomorrow and see if it works.
Old 05-23-2024, 10:22 PM
The slides I have seen have black borders all around. The raster should just fill the clear area.
Old 05-25-2024, 09:04 AM
I got it working pretty a well now. (The horizontal at the top of the screen is a little off on my other pattern generator too) My only problem is the picture is a little too far to the right. I can't seem to find a way to adjust that.
Old 05-26-2024, 01:50 PM
kf4rca kf4rca is offline
If you have or suspect vertical troubles, check the 3.3 Meg resistors for increased resistance.
