Old 08-09-2024, 10:53 AM
Mr.Duncan Mr.Duncan is offline
I forgot to mention, I have a set of these coming in the mail so I can finally test voltages with the chassis installed.
tubes by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
Old 08-09-2024, 01:00 PM
I general, don't replace composition resistors with wirewound, because they may affect frequency response of high frequency circuits. Replacing wirewound with wirewound is a good idea.
1% tolerance is a waste in consumer tube sets, because the variation from tube to tube in a circuit will completely swamp that out. The exception is test equipment where multiple low-gain feedback stabilized sections are used to make the gear maintain calibrated state at least for a while.
In transistor circuits, variations due to the transistor itself are usually much smaller than variations due to passive components.
5% film resistors when replacing other than wirewound are usually not a bad idea.
Old 08-10-2024, 07:53 PM
Checking ESR on both capacitors on the vertical circuit.
Both these new capacitors are .1uF @ 400volts.
I checked and found ESR ratings of:
C40: 16.6
C39: 16
I de-soldered them, and got the same ESR ratings, with the same .1uF.
I cant seem to find a chart/data on ESR ratings for high voltage, low uF capacitors. Are these ESR ratings bad? The uF test shows the correct uF value.
tube by Thomas Duncan, on Flickr
C40
PXL_20240810_233255415 by Thomas Duncan, on Flickr
C39
PXL_20240810_233312649 by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
Old 08-10-2024, 08:17 PM
According to this page
https://www.eevblog.com/forum/beginn...ll-capacitors/
your ESR meter may be reading the capacitive reactance of small capacitors in series with the resistance.
In fact, if you plug in 0.1 uf and the frequency of your tester (100 kHz) on this page
https://www.omnicalculator.com/physi...tive-reactance
You get 15.9 ohms
Old 08-10-2024, 08:22 PM
square root [16^2 - 15.9^2] = 1.79 ohms ESR
Old 08-11-2024, 02:10 PM
I rarely test new film capacitors, but when I do I use my Heathkit C3 which will tell me if they're going open or if they leak at full rated voltage.
I only use my ESR tester on solid state stuff.
Old 08-12-2024, 05:55 AM
For high voltage low current circuits, the leakage is the most important parameter. For high current low voltage PSU's, the ESR can play a important role.
Old 08-12-2024, 08:24 AM
kvflyer kvflyer is offline
Exactly, for what it's worth I agree, it is the way to do it.
Old 08-13-2024, 04:13 PM
Picked up a 1950's (i think) antenna for the TV, matches well.
PXL_20240813_203405669 by Thomas Duncan, on Flickr
PXL_20240813_203410786 by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
Old 08-14-2024, 05:57 AM
Great!
Old 08-17-2024, 03:23 PM
NowhereMan 1966's Avatar
NowhereMan 1966 NowhereMan 1966 is offline
Slave to 1 Cat
I have the same exact rabbit ears, my parents got them when they were married in 1959. I still use them on my 1982 Zenith.
Mom (1938 - 2013) - RIP, I miss you
Spunky, (1999 - 2016) - RIP, pretty girl!
Rascal, (2007 - 2021) RIP, miss you very much
Old 08-17-2024, 07:07 PM
I've got a set too. They were too cool to pass up. Have yet to hook them up and see if they paint the corners...
Old 08-17-2024, 09:52 PM
Still digging into the vertical issue. Removed the chassis, triple checked all capacitors, re-did all the solder points to be safe.
Swapped out both Vert OSC (6BF6) and Vert Output (6DT5) with some good NOS tubes.
Replaced R50 with a new resistor.
Still got vertical collapse. - I guess I could work backwards from 6DT5?
Set the line voltage to 117v AC.
When checking 6DT5 I got the following voltages:
  1. Pin# 1 280.1v (spec is 275)
  2. Pin# 7 20.52v (spec is 20v)
PXL_20240818_023303382 by Thomas Duncan, on Flickr
PXL_20240818_023131537 by Thomas Duncan, on Flickr
PXL_20240818_023143176 by Thomas Duncan, on Flickr
PXL_20240818_023948540 by Thomas Duncan, on Flickr
PXL_20240818_024008008 by Thomas Duncan, on Flickr
PXL_20240818_023359388 by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
Old 08-18-2024, 03:53 PM
Those voltages are completely normal. With line voltage set to the same 117V as Sam's anything within +/-25% is normal (in stages like vertical or CRT gun grid/cathode where the bias is controlled by potentiometers the normal range can be much larger than 25% and it's sometimes wise to adjust the relevant pots to make sure they can get the voltage that sam's says should be there.
If all the vertical voltages measure normal you may want to check the output transformer, and yoke and their connections to each other.
Old 08-18-2024, 05:51 PM
I'll check those tonight. I did find a low voltage PIN#7 of the 6BF6 tube.
(Vert Mult / AGC clamper)
I believe pin#7 is the output that feeds into 6DT5 Tube?
I was able to vary the voltage of pin#7 between 7.47 to 11v, but no higher than 11. (using the vertical adjustment pot)
Voltage spec: 25v
Reading: 7.47-to-11v
Some good news:
Im getting clear audio out from the TV- was broadcasting signal on channel #7 with my Blonder Tongue.
Checked the Yoke- Ohm reads are within spec.
Duncan
Houston, TX
1960 Magnavox
