Old 08-27-2024, 12:17 PM
Chris K Chris K is offline
I hooked everything up the way Penthode documented in his photo. From sweeper to counter:
Aux out to counter
Inhibit to inhibit
Blanking to blanking
Sweep out to sweep in
Sweep out from 8600 to horizontal scope input
Old 08-27-2024, 12:35 PM
OK, well inhibit isn't going to work with your scope and you have nothing on the vertical so all you will see is a horizontal line. Meaning that, so far, it looks like it should.
Old 08-27-2024, 12:41 PM
I posted sequential photos of hooking up the cables one by one because these cables are 3 feet long and too jumbled up like a plate of noodles to follow from the 8601 to the 8600. But here you go as best I can
Old 08-27-2024, 12:43 PM
But I don't see markers...Penthode showed this setup without a vertical input and he had 5 markers on the horizontal trace. That's what I'm trying to reproduce but there are no markers.
Old 08-27-2024, 01:03 PM
Would a Textronix 465 make all of this easier if I can get my hands on a working one?
Old 08-27-2024, 01:07 PM
you said you had an analog scope, what type is it?
Old 08-27-2024, 01:10 PM
In the latest picture but I haven’t used it in years and one of the beams is messed up
Old 08-27-2024, 01:36 PM
Penthode's Avatar
Penthode Penthode is offline
Just any plain old scope with a an X-Y display will work. Is something inhibiting the display? Make sure the scope is not set to trigger.
Without the RF connected you should see a horizintal line trace. The dots will appears when the marker controls are set mid position. Remember if the marker controls are set fully CW or CCW, you will not see the dots. (And CW in this case is Clock Wise!)
Let's look for the sweep line first. What is inhibiting the trace on the scope? If the sweep output of the generator is not reaching the x input of the scope, you should just see a dot in the center of the screen. It may be you have the scope set to deflect the trace off screen to the left or right.
Maybe to start, let us see the scope display with a dot in the center of the display with NOTHING connected. Then connect the sweep x input to the scope. You then need to raise the brightness and/or adjust the scope X channel centering control. Also make sure you start with the highest setting of the v/div control and it would be useful to begin with the X Channel set to AC input.
Old 08-27-2024, 01:40 PM
I can't see any pics here @ work...
will have to wait till later.
Correct. You will NOT see markers using the setup he outlined using a digital scope. You cannot reproduce it using the HP digital scope using the inhibit technique.
I suggest you try connecting the Z-axis output to the z-axis input on the digital scope. If that doesn't work, you will have to use an analog scope.
Yes, a 465 or 2213 will work. Rotate the timebase on the 2213 to XY
Old 08-27-2024, 02:48 PM
I have the 3MHz sweep line. What I don’t have are the markers. When I push in the button to select a marker I get a read on the marker Nikki tubes that’s very unstable and unreadable
Old 08-27-2024, 02:54 PM
Z axis input on the scope? Where is that? I have 3 BNC inputs on the scope…X Y and external trigger
Old 08-27-2024, 02:58 PM
external trigger is the z-axis input in XY mode
Old 08-27-2024, 03:23 PM
Here is a picture of the settings on my analog scope and the trace. Those blips on the line, I can't move them or put anymore on the line so I don't think they're markers nor do I know if I have this scope setup correctly other than having it in X-Y mode.
Old 08-27-2024, 03:24 PM
BTW I set the center frequency down to 22.25MHz
