Old 09-05-2024, 08:18 AM
Penthode's Avatar
Penthode Penthode is offline
Have you checked if the 6AL5 is lit?
Old 09-05-2024, 08:39 AM
Chris K Chris K is offline
No not yet. I'll do that this evening
Old 09-05-2024, 07:25 PM
6AL5 is fine. New scope in and working. Got the trace...BUT IT'S BACKWARDS!
Old 09-05-2024, 07:45 PM
Penthode's Avatar
So the other scope was sick?
To ensure we are on the same page, please define backwards. Do you mean the x axis is scanning right to left? If so that suggests a polarity inversion on the x channel input.
And why is part of the trace darker? is the photo accurate to what you see or is there a shutter speed issue? If it a shutter issue, perhaps reducing slightly the scan trace speed will help.
Old 09-05-2024, 07:51 PM
Yes I believe the other scope was sick. This one gave me bright, clean and sharp traces.
By backwards I mean it's like a mirror image left to right like the trace rotated 180 degrees around the Y axis.
The picture being darker on one side is a shutter issue. It's a great trace, crisp, clear and of equal brightness intensity throughout.
Old 09-05-2024, 07:52 PM
BUT...the markers are in the right places so maybe the rotation is with reaspect to the X axis
Old 09-05-2024, 07:54 PM
On a symmetrical trace like this, how do yoiu know if it's the horizontal or vertical that's reversed?
Old 09-05-2024, 07:56 PM
By the frequency of the markers. It's rotated 180 degrees around the X axis...my mistake earlier
Old 09-05-2024, 08:13 PM
Penthode's Avatar
The 8601a is a ramp waveform sweep to the x axis input. If the trace is backwards, there must be a phase inversion switch on the x channel input at the scope.
Old 09-05-2024, 08:18 PM
Penthode's Avatar
Is that an invert button beneath the volts/div control?
Old 09-05-2024, 08:21 PM
Penthode's Avatar
And can you reduce the sweep speed slightly on the generator (little knob on the lower right from panel) so that the photos show a bright clear display for us?
And I should add that on late 40's RCA TVs, almost all have the 5.1 ohm series filament resistor to the 6AL5 discriminator. I have restored about a half dozen of these sets and four of the resistors were bad or became bad shortly after coming back to life. So be prepared if you loose sound to first look to see if the 5.1 ohm is bad.
Old 09-05-2024, 08:28 PM
It says waveform off
Old 09-05-2024, 08:30 PM
I will check the resistor. I tried changing the sweep rate on the 8601 and took a series of photos...they were worse
Old 09-05-2024, 08:37 PM
About as good as I can get
Old 09-05-2024, 08:39 PM
Manipulated the photo a bit
