Old 09-06-2024, 07:58 PM
Chris K Chris K is offline
If we do move on to the adjustment of T-112, I'll need help! I'm confused by the instructions to input a signal and the sweep separately.
Old 09-06-2024, 08:10 PM
I got it...just a change in signal input to V116 pin 1
Old 09-06-2024, 08:14 PM
Penthode's Avatar
Penthode Penthode is offline
Can we finish T113 first? You still do not have the display right.
Old 09-06-2024, 08:28 PM
Almost impossible to photograph these. Maybe I'll have to turn the overhead lights off. Anyway, good symmetrical trace adjusting T-112 with 21.25 at the peak. Very low signal input.
Old 09-06-2024, 08:29 PM
What's wrong with it?
Old 09-06-2024, 08:35 PM
Penthode's Avatar
Your sweep was too narrow and you could not see the baseline to achieve symmetry.
The x gain is too low and your sweep too narrow on T113 and your latest display.
Old 09-06-2024, 08:36 PM
Penthode's Avatar
Just a bit more width so we can see the response skirts.
Old 09-06-2024, 08:39 PM
Better????
Old 09-06-2024, 08:45 PM
Penthode's Avatar
Now go to the 8601a and increase the sweep width
Old 09-06-2024, 08:47 PM
Penthode's Avatar
You may have to go to the next click position and then reduce using the vernier. We want to see more of the waveform skirts left and right.
Old 09-06-2024, 08:49 PM
Old 09-06-2024, 08:56 PM
Penthode's Avatar
That's better! I wanted to see the left right of the S to see the baseline and symmetry..
Old 09-06-2024, 08:57 PM
Penthode's Avatar
However could you ensure the 21.25 marker is set? It now says 21.06.
Old 09-06-2024, 08:58 PM
So good to move on to alignment of the sound IF, T-112?
Old 09-06-2024, 08:59 PM
Yes it is set right on frequency and the bright dot in the center is the marker. The frequency on the counter is one of the curve apex markers
