Old 01-12-2025, 01:14 PM
CJVx CJVx is offline
Actual purpose of dag coating?
I looked around and couldn’t find an actual described purpose of the coating. I ask because I have a few TVs with various states of missing dag, But don’t seem to have any operational issues, however, there is room for improvement. Wondering what I could be missing should I redo the dag.
Old 01-12-2025, 03:20 PM
Retired Batwings Tech
Its the negative plate of the vacuum capacitor of the pix tube glass bell
Old 01-12-2025, 04:09 PM
All right, so what would happen should the dag not be present?
Old 01-12-2025, 06:47 PM
The CRT bell is a big capasitor. One plate is inside the CRT & hooked
to the HV lead. The glass is the dielectric. The dag is the other plate
of the cap. Without the dag the HV is unfiltered & instead of DC the HV
will be pulsating.
You can recoat it but MUST follow the old pattern.
The dag usually goes to chassis ground via a long spring across the dag.
If much of the dag is missing you may get arcing, hissing & ozone smell.
HV will also be reduced. The other thing is if the dag is flaking off the
flakes fall onto the chassis & can cause shorts.
Old 01-15-2025, 12:22 PM
Basically, old models using eg. metal coned CRT uses external capacitor (a "doorknob" type).
Old 01-16-2025, 12:08 AM
Slipplate is a good replacement coating. Generally you want to avoid dag islands as they can arc to each other and cause picture disturbance/video noise, and if arcing between islands (or between the dag and a poorly contacting ground strap) is constant and bad enough it can unevenly heat the glass and cause implosion.
Old 01-16-2025, 06:00 AM
dag islands ? aren't they just off the coast of Florida?
Old 01-16-2025, 10:24 AM
Wink
They could be yours if the price is right
Old 01-17-2025, 01:30 AM
TV-collector's Avatar
TV-collector TV-collector is offline
If you have graphite dust / -flour you can mix it with wood glue and paint it with a paint brush on the right areas.
That advice came from my physics teacher in the 70s and it worked very well!
Please clean areas in question before.
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
