Old 02-24-2025, 06:24 PM
I replaced the coupling cap from the volume control to output amp. That got the sound going.
Waiting on parts from Canada to continue.
Meanwhile, here's a comparison of "normal" versus "zoom" mode. Bad compression on the right side.
Old 02-24-2025, 06:56 PM
the picture looks a bit M*A*S*H ed!
Old 03-01-2025, 05:35 PM
For as few parts as you've changed the picture looks quite sharp.
Old 03-02-2025, 04:20 PM
I decided to give these JFX premium polypropylene caps a try. I got them from Just Radios.
I figured black was a nice change from yellow Long leads and easy to work with.
Also, if one was so inclined, they do fit nicely inside a cracked open bumblebee.
Replacing a couple caps on the horizontal output tube helped the smooshed right side.
Old 03-04-2025, 06:28 PM
That's looking better!
Bob after seeing all these nice looking restuffed caps you've done, you're getting me more inspired to start restuffing caps. I did restuff the electrolytics in a Marconi portable tv radio combo (Emerson 1232) and they turned out nice. They were the paper can multicaps with the shellac end like you'd find in an AA5 radio. I wished I had axial lead caps on hand when I replaced the wax paper caps. I may revisit it in the future and swap them out with the restuffed originals.
Old 03-05-2025, 10:23 AM
Still having both vertical and horizontal linearity issues, but the image is looking pretty good.
There are three multi-section electrolytics on the main chassis I haven't touched yet. That includes the vertical output cathode bypass cap. I expect replacing those will help.
Old 03-12-2025, 10:09 AM
While certainly not necessary, restuffing these old bumblebees is fairly easy and I think looks nice.
I'm just leaving the black caps as is when replacing the grey ones.
Just about done
Old 03-12-2025, 12:52 PM
I'm impressed you can reliably split them like that. I've found that unless the paper inside swells and they split themselves in half cleanly, they usually shatter into a mess of jagged bits when I try to split them.
How are you splitting them?
Just about done
Old 03-12-2025, 04:00 PM
Here's a short video showing the process. I've gotten better since I made this.
Fresh utility knife blade placed right along the seam plus a few taps from s small hammer.
Flip it over and do the same on the opposite side.
https://youtu.be/MVjdW_CmO6c
Old 06-30-2026, 11:52 AM
Finally getting back to this set hot off the heels of a 28T962 with nearly identical chassis. https://www.videokarma.org/showthread.php?t=277669
Wrapped up the recap and breezed through the alignment since it was fresh on my mind.
This set has a 12LP4A rather than the aluminized 12KP4 in the 28T962. Even so, the image quality is comparable.
It certainly has great bandwidth with very visible chroma dots.
Now, if I could just find a set of chrome control doors...
