Old 04-09-2026, 02:56 PM
You mean 25L6?
IIRC the 25L6 has lower plate power specs than the 6L6 (which is unusual for a series string version of a 6V tube).
Old 04-09-2026, 03:14 PM
Yeah, that's what it is, I have not seen this tube before, I thought it was a 25v version of a 6L6 :P
Old 04-09-2026, 04:17 PM
Yeah, I don't know how they got away with that. Very, very confusing!
Old 04-09-2026, 06:47 PM
The size difference is , interesting!
http://suzaku.live-evil.org/20260409_183938.jpg
Old 04-11-2026, 01:12 AM
Someone did some sloppy work in the HV part down there.
http://suzaku.live-evil.org/20260411_000050.jpg
frayed wires, pointy bits. all the things you dont do.
Old 04-11-2026, 11:19 PM
those 2.2m meg resistors don't have to be HV types do they? SAMS just says 1W for the voltage divider.
Old 04-12-2026, 11:34 AM
dtvmcdonald's Avatar
Its closely related to the pentode part of the 117L7 pentode-rectifier and similar 117v tubes (M7, N7, P7), which I believe predate it, though I can't prove that.
Old 04-12-2026, 03:59 PM
Here is a better shot of the nightmare waiting for me in the HV deflection control area, I test fit one new caps, just to se how it's going to go, someone has been there before, cold solder joints in the resistors, peaks, burned wires, burned Cap?
I also snuck in a cameo of the new pin cap for the 21FJP22A.
http://suzaku.live-evil.org/20260412_154430.jpg
Still waiting for more adapt-a-caps, want to do the PWS section first.
Old 04-12-2026, 04:32 PM
Nightmare? That looks as nice as open as I've ever seen.
Old 04-13-2026, 08:21 AM
+1
If you want to see a nightmare find a 1942 Zenith Consoltone bakelite table radio, or some of the Silvertone table model radio-wire recorders....Darn things are full of brittle rubber wiring and have caps so buried under other parts you have to partially dismantle the circuit to do a recap, and everything you touch cracks insulation off the wires (the chassis are wired like someone decided to fit 15lbs of crap in a 5lb box)... it's like playing the game operation on hell difficulty mode by comparison. Touch one thing and you're replacing every wire.
Old 04-13-2026, 11:13 AM
It's almost as if that area was built from kit, or someone re-built it who did not know what they were doing, frayed wire connections and peaks are a big no-no when it comes to 5kv+ circuits, I'm going to get some 6k rated wire when I redo that area, gonna use regular 1w film resistors, one of which is just wrapped around the post, no solder, I don't think this set ever worked.
Old 04-13-2026, 08:46 PM
Of course the HV PWS is a bit different than shown in the SAMs.
Old 04-14-2026, 12:08 PM
If you want evil component placement, try a Hallicrafters SX-28 SW radio.
I built a special soldering gun tip out of #8 wire, insulated (electrically and thermally) with thick Teflon tubing that was 4" long, so it could be bent into a snake to
reach down into the nest. I bought a pile of cuticle scissors at the drugstore
to cut wires down there. Expendible.
Old 04-22-2026, 07:24 PM
This USED to be a 1.2k resistor... but not any more!!!
http://suzaku.live-evil.org/20260422_191559.jpg
It go BOOM!
http://suzaku.live-evil.org/ooops.jpg
says it was a 1w on the b- line, putting in a 2w.
gonna be a while till I can do a test power up.
Old 04-23-2026, 08:04 AM
It go BOOM!
Did you find What cooked that resistor
