Old 04-03-2007, 10:54 PM
blue_lateral's Avatar
Nice set. Some friends of ours had a similar set when I was growing up. It too had 3 speakers and push-pull audio. Is your audio section on the TV chassis?
Regarding the buzz, too much signal strength will also do that. Does it have an AGC pot? Maybe it's set too high.
John
Old 04-04-2007, 10:32 AM
Reece's Avatar
Reece Reece is offline
Super picture!
Reece
Reece
Old 04-04-2007, 10:39 PM
Tony V's Avatar
Tony V Tony V is offline
Awesome set Charlie!
Old 04-05-2007, 02:33 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Much better now
Thanks for the good words, guys. I happy with the way things turned out.
As Andy pointed out, tweaking the discriminator reduced the buzz greatly. There is still a little there... probably needs an alignment... but it's a hell of lot better now.
Regarding the sound, my Philco Diamond D hits the bass really well only using one 6x4 speaker and a 6AQ5. Since this Hoffman has two 6BQ5's and two 8" speakers, I was really expecting bass response more like the Philco. Don't misunderstand... the Hoffman sounds really good for a 50's TV. In fact, I can crank the Hoffman's volume control all the way up to the stop... and not one bit of distortion!
John: Yes, the audio is on the TV chassis. I tried the AGC... not much affect there... but good sugestion.
Changing a couple of resistors in the verticle section fixed the occasional roll. I couldn't find the reason for the verticle being steady at the stop of the pot... everything checked well within spec... so I replaced a 1.2 meg resistor off the grid of the oscillator with a 910k resistor... and that put held the picture right in the middle of the control.
Charlie Trahan
Old 04-05-2007, 03:54 AM
cincy cincy is offline
AK Member
Nice set Charlie--I bought a Hoffman 19" tabletop b&w new in 1960 and it was more expensive than other sets of the same size--like Whirled One said they were sold mostly on the west coast. Yours is the second one I've ever seen.Good Luck with your find.
Old 04-06-2007, 09:35 AM
Reece's Avatar
With those speakers the Hoffman ought to have good bass. If not, increasing the size of the audio coupling caps should help. Also, be sure that the two 8" speakers are in phase, cones moving in the same direction, not one in and one out. A good way to test is with a flashlight battery (this is probably old news!)
Reece
Reece
Old 04-06-2007, 02:19 PM
Charlie's Avatar
On Land
Yes, the speakers are in phase... that was the first thing I checked. It really does sound fine the way it is... I was simply expecting the same thump I get out of my Philco.
Increasing the audio couplers size, eh? Hmmm... perhaps I will toy with that for fun!
Charlie Trahan
Old 04-06-2007, 04:59 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
I think that's your answer Charlie, it's doing what it was designed to do.
Pete
Old 04-06-2007, 06:47 PM
peverett peverett is offline
The Hoffman company is based in Los Angeles. They are now Hoffman Video Systems. However, they did have a factory in St. Louis, Missouri at one time. I have gotten several sets here in Texas and seen others in the midwest. These probably came from the St. Louis factory.
Old 04-06-2007, 08:32 PM
Charlie's Avatar
On Land
Pete
Pete, that's a good point. You're absolutely right. Kinda goes along with if it ain't broke, don't fix it!
Charlie Trahan
Old 04-06-2007, 09:22 PM
LBPete's Avatar
LBPete LBPete is offline
Rolling Along
That looks like a great old TV. Hoffman made other consumer electronics. I picked up a Hoffman AM/FM transistor radio recently. In the early and mid 60's they made transitor radios powered by solar cells. Somewhat ahead of their time.
- Pete
Old 04-06-2007, 09:53 PM
Charlie's Avatar
On Land
- Pete
Yep... got one right here.
Charlie Trahan
Old 04-09-2007, 07:05 PM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
why does everyone else have all the luck... my poor 21-T639 is still sitting outside on the porch
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
