Old 12-09-2007, 12:00 PM
Originally Posted by Tubejunke View Post
It looks quite a bit bigger than a 19" to me. There were some large round tubes made, mostly used by DuMont. The 19AP4 does seem to get a bad rap. I wonder if other metal/glass crts are as troublesome. The issue is vacuum loss at the seam. If that were the case they all would be trouble.
I wonder why they ever made the metal tubes.
I once had a Majestic TV (1951 model) which had a round 16GP4 CRT (metal cone). Never had one bit of trouble with the tube losing vacuum or anything else. Also, I did not realize that round CRTs had seams anywhere in or on them; in fact, I don't recall seeing a seam anywhere on the 16GP4 in my set. (I learn something new all the time reading the posts in these forums.)
Round metal-cone CRTs: I agree with you one hundred percent. Those tubes worked well enough, but the metal cone created the heck of a HV shock hazard, as I think the cone was one half of an HV filter capacitor, the bell of the tube being the other (this technique, IIRC, replaced doorknob HV caps in many if not most 1950s sets with round CRTs). IMHO, the best thing ever to happen to television CRTs was when the manufacturers gave up on metal-cone tubes and switched to glass exclusively, which all but eliminated the shock hazard.
Old 12-09-2007, 03:13 PM
Whirled One's Avatar
Whirled One Whirled One is offline
Originally Posted by jpdylon View Post
Just a rarity. I see the standard looking SC stuff from time to time, but never ones that look like this.
I suppose I should have said, 'Its not one you'll see anytime soon'
THe SC modular chassis were very well designed and are a breeze to work on. They also produce a pretty damn good picture.
I think you may be confusing Stromberg-Carlson with Setchell-Carlson; they were two different companies. Setchell-Carlson sets were known for having a modular "unitized" chassis, but weren't Stromberg-Carlson sets more typical in construction..?
Old 12-09-2007, 05:06 PM
The metal cone tubes have a seam where the glass face is bonded to the metal cone, they also have a seam where the neck is joined to the other end of the cone.
That said I have a 50+ year old 16AP4 that is still holding vacuum as was the worn out tube it replaced.
I think the bigger tubes (19", 24" 30") probably had more problems because of the larger joint surface and the extra expansion contraction problems.
The metal tubes don't hold a charge on their own but I guess you could still get shocked with the set off if the doorknob cap was charged up.
Old 12-09-2007, 07:10 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
You're right setchell carlson is what I was thinking of.
Jordan
Old 12-10-2007, 01:12 PM
Tony V's Avatar
Tony V Tony V is offline
Dont feel bad as i get the two confused once in awhile myself. Still a cool tv though.
-Tony
Old 12-12-2007, 12:46 AM
Captain Video's Avatar
Captain Video Captain Video is offline
Load of TVs - US$ 50 each one
http://cgi.ebay.com/16-VINTAGE-TELEV...QQcmdZViewItem
Old 12-12-2007, 11:39 PM
jpdylon's Avatar
A mid 50s Halolight
http://sandiego.craigslist.org/csd/clt/505328826.html
Not mine.
Jordan
Old 12-13-2007, 12:52 AM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
50's (?) RCA set
I didn't see this one on the first page, so here it is:
http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget
The seller says he blew a resistor by turning up the focus control. I wonder what that means? Maybe he incorrectly replaced a cap or two? Looks like a nice little set.
Sony Trinitron Fan
Old 12-13-2007, 12:57 AM
David Roper's Avatar
console lover
He doesn't do grill cloth either!
tvontheporch.com
Old 12-13-2007, 12:58 AM
I didn't know that model had grill cloth. Was it supposed to wrap around the entire top half of the front of the set?
Sony Trinitron Fan
Old 12-13-2007, 01:11 AM
console lover
tvontheporch.com
Old 12-13-2007, 01:15 AM
That looks quite nice on the stand.
Sony Trinitron Fan
Old 12-13-2007, 10:04 AM
veg-o-matic's Avatar
veg-o-matic veg-o-matic is offline
Huh?
A Rarity!
RCA "Victory". Guess that means it's post-war, huh?
http://baltimore.craigslist.org/hsh/507856749.html
veg
Old 12-13-2007, 03:38 PM
veg
Hahahahahahahahahahahaha!!!
Old 12-22-2007, 03:33 AM
Admiral Combo on Goodwill MI
http://www.shopgoodwill.com/viewItem.asp?ItemID=3245420
