Old 02-28-2008, 05:58 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Early Emerson TV's (1947-49) Any Good?
Are they? What are their strong and weak points?
Thanks;
LJB
Old 02-28-2008, 06:51 PM
Old1625's Avatar
Old1625 Old1625 is offline
Probably a "middle of the road" designed set. I had a table model with a 12LP4 that had gone gassy, and never did find another to replace it. It was a pretty set, but I had to downsize at the time, and it went into the dumpster.
Old 02-29-2008, 03:16 PM
snogcel's Avatar
snogcel snogcel is offline
AK Member
Old Emerson TV
Greetings!
I have an old 1948 vintage Emerson set, which works pretty well. While Emerson was considered to be something of a "low end" brand, I've seen quite a few Emersons around and still kicking.
The set's weakest area is the power supply. To avoid using a costly power transformer, they used a couple of voltage doubler setups instead, built around selenium "stink bomb" rectifiers.
Sporting a cluster of nine electrolytic cans mounted on the chassis, along with a ballast resistor unit that gets amazingly hot during operation, I'm always expecting to smell something bad at any time. It keeps on going, though.
Reception is just so-so, but looks pretty good when I set it on Channel 3 and use an old analog cable TV box for reception. All of the controls are on the front, and for good reason: Everything seems to need touch-up adjustment during the course of regular viewing. But the set gets a lot of "Wow" comments from visitors!
If you've got one, go ahead and fix it up - it should be worth the trouble.
Good luck!
Old 02-29-2008, 03:45 PM
M3-SRT8's Avatar
Yup. Sounds like my 630 TS, sans the power supply mods. I think the Emersons look pretty.
I kinda like tweaking it...the 630TS, that is.
LJB
