Old 02-26-2011, 04:17 PM
Adam's Avatar
Adam Adam is offline
Talking Wall of Zeniths
I'm about to start working on the 2 leftmost consoles, the others are all restored and working. All that's wrong with the one on the left is the remote not working, the middle console has trouble with the vertical.
Old 02-26-2011, 06:11 PM
Cool photo
Good luck fixing them.
Old 02-26-2011, 07:28 PM
Cool zeniths! If 2 of my 4 were not on a diferent wall and dismantled in the garage respectively I'd take a photo of the four and post it. I'm amazed how many space command equiped models you have! I just have one that I got off the ETF clasified free section a few months back. The fellow I got mine from is a real class act, earlier this week he stumbled across the original instruction manual and sent it to me free of charge!
Old 02-26-2011, 08:07 PM
Adam's Avatar
That's not even all of my b/w Zeniths. I have 9 total, all working except for those 2 consoles I previously mentioned. The b/w metal table models are my favorites. I'd like to eventually see if I could find one for every year Zenith made those.
my metal table models:
'60 17" SC300
'61 19"
'63 19" SC300
'66 19" SC300
'67 19"
'71 23"
and the 3 consoles:
'60 21"
'61 23"
'61 23" SC300
Old 02-26-2011, 08:10 PM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
I'd love to stop by sometime and view your collection Do you have a tube tester? I can't find mine anywhere
-J
Old 02-26-2011, 08:17 PM
Adam's Avatar
You need to test some tubes? I've got a Sylvania 220, a Superior TV-11, and a Sencore TC-28 with a busted meter.
Old 02-27-2011, 04:21 PM
Adam's Avatar
Well I've been looking at the '60 console. It turns out the actual problem with the vertical was the vert lin control itself. There were a couple of dead spiders stuffed in there, and it seems they were pulling it apart, There was a ball of fine wire in there which I think was unravelled from the control itself. Either way, you turn it, and it just goes from basically open to shorted with nothing inbetween.
The set also had the usual 60 cycle hum in the picture, so I know I have leaky electrolytics in the power supply. I'm just going to recap while I'm in here, electrolytics and the few "bumblebee" caps that are still in here while I'm at it.
Old 02-27-2011, 07:05 PM
radiorich radiorich is offline
VK Member
Hello Adam,
Very cool I think I may have the very far right top zenith in my collection some where.
I do have a later 50s like 17 or 19in zenith tabletop thou.
Rich
Old 03-03-2011, 09:53 PM
Adam's Avatar
I recapped the '60, and put a new vert lin control. I got sound and picture but no sync, horiz or vert, but the freq is not way off on either, the picture just slowly drifts side to side and top to bottom, won't lock in. Anyway, I located the problem to be a bad 22k 2w resistor affecting the sync separator tube, unfortunately I don't seem to have one, I'm going to have to order one and wait for it to come. I miss the days when you could just buy this sort of thing locally.
Old 03-04-2011, 01:05 AM
Tubejunke's Avatar
This looks like the perfect home for my much talked about beautiful 58 or 9 24" Space Command. I have told its story so many times that I might get fragged if I go through it again. Long story short I recapped the Zenith and I have not been able to get vertical height of more than maybe an inch or two. I think that it was a factory defect as the set looked as if it had hardly ever been used when I got it. All original tubes and no evidence that the back cover had ever been off. When I got stumped on the vertical issues I lost interest and could not even GIVE the set away, so I have been trying to find someone particularly familiar with that generation of Zenith chassis and typical problems with them. I have only heard that they were great performers! That only rubs it in for me knowing that I have a "great performer" in great shape, with a nice big screen that I can't even use!
Old 03-04-2011, 11:21 AM
Reece's Avatar
Reece Reece is offline
Nice wall of Zeniths. Open a showroom, sell them like hotcakes!
Reece
Old 03-04-2011, 06:32 PM
Adam's Avatar
The '61 console is working, I recapped it, but all that really wasn't working with it was a couple weak amplifier tubes in the remote receiver.
Old 03-10-2011, 08:35 PM
Adam's Avatar
All 6 working now.
Old 03-10-2011, 09:13 PM
Wow - nice
Old 03-10-2011, 09:29 PM
stromberg6's Avatar
All 6 working now.
Hope I can find a nice 21 inch B/W set that will produce as nice a picture as your Zeniths . Thanks for the pics!
Kevin
stromberg6
