Old 04-10-2011, 09:44 PM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
Yourtube video on how to pack a monitor. I'm not convinced this will work for a vintage CRT. Pressure would be applied to the neck as the foam expands and being contained in the pack it couldn't flow, especially if the face of the CRT is being held in place. A poured foam wouldn't have that problem. The seal between the glass and the metal on the composite CRT is the critical issue. I wouldn't want those areas to be put under any unnecessary pressure. Even a CRT like a 12LP4 is fragile where the neck expands.
http://www.youtube.com/watch?v=F4YDzwEA3v0&NR=1
Old 04-11-2011, 08:30 AM
John Q
I slept on this overnight and have changed my mind a bit. I think it still needs to be double boxed. UPS is just to careless with these packages. The expanding foam will work great for the inner box and will provide a lot of rigidity which is what is needed in the inner box but without the second outer box the filiment will still be subject to shock damage.
