Old 07-19-2011, 03:10 PM
Zenith26kc20's Avatar
Nice picture! Wow, cramped little critter!
Old 07-20-2011, 12:45 AM
Red Raster's Avatar
Red Raster Red Raster is offline
Originally Posted by Phil Nelson View Post
Great results. That set looks tedious to work on. Servicemen must have hated them!
Phil Nelson
And i will have to learn to like em, I have 4 more GEs with variations of this chasis.
Although there were some tight and trick spots, The layout made checking B+ voltages very easy and going through the voltage doubler rectifer cap circiut was a snap as i did have to replace the selenium diodes and verify that i got it right the first time around. Stuffing the multi section eletrolytics were also quick and clean, Both caps are sleaved with cardboard covers and i was able to cut the cans close to the base, stuff and pop on the cardboard covers on leaving a factory original look. All in all the job posed some challenges that i was able to overcome, through past expirences and inovative technics i have picked up from others on this forum.
Old 07-20-2011, 01:07 AM
Red Raster's Avatar
Great question!
Wow! Nice job
What type of capacitor did you use for restuffing the 150uF @ 150 volts caps and how did you managed it so cleanly ?
I soon realised that 150uf/150v capacitors would be hard to find so i cheated, under the cardboard wrappers are two caps, a 100uf in parallel with a 47uf. The capacitor checker reads 144uf and the set is working good.
In the other GEs i will try two 80uf caps in parallel. On another note i have found a pipe cutter that will open up to 1 1/2 inches and will cleanly cut the aluminum can in two, making resuffing some caps a whole lot easier.
Old 07-20-2011, 01:56 AM
Thanks for the tips. I have have two of these chassis awaiting restoration. I dug up some 220uf @ 200 volt caps I was going to try. I wonder if that extra capacitance will pose a problem
