Old 09-15-2011, 09:42 PM
I worked on the knobs on my lunch hour today.
I made a board to mount them on and attached three machine screws to it and one 1/4" bolt for the tuner knob, grind a flat on them and instant knob shafts.
I also extended the IR sensor for the remote with some ribbon cable, also the LED power indicator.
For the power indicator I wanted it to look neat without drilling a hole in the cabinet to mount it, my solution was to drill a hole in one of the knobs instead.
I removed the Brass plated cover and drilled a hole in the knob about the same diameter as the LED, I didn't want it sticking out through the cover though so I only drilled out two of the small squares on the cover and slotted it out as best I could with a drill bit.
The result is a discreet pilot light that doesn't stick out like a sore thumb, at least I hope it doesn't, I haven't turned it on yet to see how it actually looks.
The flash made the LED glow green in the picture so that's a pretty good indication of how it'll look.
The Escutcheon is from a Teletone, it had most of the numbers worn off so I polished it up nice and shiny, I think it looks good, if incorrect. (like that matters here!)
I'd like to install a power button behind the original on/off knob, it'll be push on push off, it shouldn't be too hard to install a micro switch behind a spring loaded shaft, I think there's quite a bit of room behind the knob board and the TV chassis.
Here are some new pics.
Old 09-15-2011, 10:31 PM
Hmm, the green light is only on in standby, oh well, it still looks cool.
Old 09-16-2011, 12:00 PM
You could always connect the LED to a power supply line that is only on when the set is if you prefer a pilot light to a standby light...
Old 09-16-2011, 09:18 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
Originally Posted by Findm-Keepm View Post
Um.....
What typeface is used for that funny chart? I've been looking for a typeface that is just a little to the practical side as opposed to Comic Sans.
Old 10-03-2011, 12:35 AM
Filled in the lettering today with some brown acrylic paint, water based, just work it in with a fingertip and clean off the excess with a damp paper towel.
Looks awesome!
Old 10-04-2011, 02:44 PM
Looks awesome!
That does look very sharp.
Old 10-04-2011, 11:09 PM
Nice job I wouldn't worry about clear coating it. I use that same kind of paint and it holds up well over time.
Old 11-05-2011, 04:44 PM
vinljnkie's Avatar
vinljnkie vinljnkie is offline
Urei 1620 DJ
I was thinking when it was red and white that it should have had a Coca Cola logo on the side of it.
