Old 07-16-2012, 09:49 PM
Thanks. I'll keep my eyes out for them, but I expect it won't be easy.
I brought the Sonora inside for a closer look.
It's one weird set for sure. Continuous tuner using variable capacitors and a voltage doubler for the HV.
A 12LP4 only needs 11 KV so I don't see why they bothered with a doubler.
It looks to be in very good original condition.
I sure hope that flyback is good.
The cabinet is pretty cheap, but in OK condition.
Just one big problem so far. The NU-Video 12LP4A has excellent emissions, but a stubborn G1 short. I've tried blasting it a few times with my CR70 to no avail.
I'll let it go for now and try again another day.
Old 07-16-2012, 10:31 PM
Now as for the Westinghouse, it's really well built. At least the chassis is anyways - the cabinet is a little flimsy.
The 10BP4 showed an H-K short at first but it seemed to clear itself out and has excellent emissions and life test now
I also found another Sonora knob hiding inside.
Old 07-16-2012, 11:00 PM
mpatoray's Avatar
mpatoray mpatoray is offline
Bob,
The Sonora has filter and bypass caps that just SNAP into a holder!!! Wow Now that makes recapping and restuffing unbelievably EASY!
Nice sets, I really like that Westy!
Another series of videos will be forthcoming I am sure.
Keep up that good work!
Matt
Old 07-16-2012, 11:10 PM
The rubber corner mounts on that Westy may indicate that Philco built the chassis, though it appears to be unique to that set.
We know from Phils experience that at least one Westinghouse has an actual Philco chassis inside.
I had my H196 a long time before I realized the lower front trim pulls off to access the adjustments!
Old 07-16-2012, 11:13 PM
By the way, the schematic for the Sonora is posted at the ETF Site.
http://www.earlytelevision.org/image...2-303-Sams.pdf
It's only the schematic but that's all Sams has for it.
Old 07-16-2012, 11:35 PM
Yes, I recorded some video while poking around these sets.
Thanks for the link. I also found the Sonora in Riders Vol 5. Four pages of info including a parts list and alignment instructions
I was thinking Philco too as soon as I noticed the rubber mounts and perforated chassis.
Old 07-17-2012, 11:18 AM
DavGoodlin's Avatar
Motorola Minion
That's interesting that the Sonora uses 1V2 for HV rectifiers. I thought those were only used in color TV as the focus rectifier. The schematic is really easy to read too
BTW the building that Westinghouse had in Sunbury later manufactured Celotex insulation.
Old 07-17-2012, 11:23 AM
kvflyer kvflyer is offline
I think my 12 inch Westinghouse set uses the 1V2 as a high voltage rectifier...
Old 07-17-2012, 07:53 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Am I seeing things or does that Westinghouse have 27 tubes? Far out that is a lot for a mono set! Impressive
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
Old 07-17-2012, 07:59 PM
The 1V2 can only take around 7,000 volts so it must be using a doubler too.
Yep, 27 tubes and 260 watts
Old 07-18-2012, 12:34 PM
mpatoray's Avatar
27 tubes and 260 watts perfect for making this summer more enjoyable! Now you just need an RCA TK-30 camera chain to go with it
Matt
Old 07-18-2012, 04:30 PM
No kidding. I just survived another round out in the baking garage and brought the RCA guts inside.
The 16GP4 immediately had excellent emissions, no shorts and rock solid life test I dig the bright red coating - do not touch!
The chassis looks OK too.
Old 07-18-2012, 05:01 PM
You've been getting some neat sets lately, I look forward to seeing 'em running. The bright red paint indicates that 16GP4 is a rebuild. Are you gonna restore the RCA too?
Old 07-18-2012, 05:17 PM
Thanks for the info. I hate to admit it, but I do plan on parting out the RCA. The cabinet is really beat up and stinks
If someone would like it, feel free to contact me. I won't be holding on to it for long.
Old 07-18-2012, 05:42 PM
Yah, my Westinghouse H-181 is a rebadged Philco 48-1001. The Philco number is rubber-stamped on the back of the chassis.
Phil Nelson
Phil's Old Radios
