Old 12-05-2012, 03:51 PM
I usually just give the neck a good sideways whack, never had a problem but I suppose there's always that one n a million chance something will go wrong.
I don't like the punch on the anode methode, like Charles said, it better be sharp or you will be putting a lot of stress in the worst possible place, a drill would be safer I think.
A drill through the end of the base cap is pretty good too, it just breaks the evacuation nipple and that is much thinner glass than anyplace else.
That's what i do with the 7JP4's because there's no anode and no real neck to speak of, it's the only safe place to puncture those tubes.
Old 12-05-2012, 08:34 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Yeah, i was drilling the anode hole out to stick a cord through it. Yeah, you guessed it... was attempting a lamp, folks did it with booze bottles, so i figured what the heck?
Unfortunately, the glass cutter i used didnt cut the neck right and i scrapped the project..
So... did i open a can of worms, anyone attempt this or SUCEED???
SR
Old 12-05-2012, 09:37 PM
marty59's Avatar
marty59 marty59 is offline
Originally Posted by kx250rider View Post
Better make it SHARP, and fine-gauge, or the force of driving the punch or scribe into the metal anode, will implode the tube by breaking the side wall.
Charles
Oh I agree! But you would be surprized at how easy a little light tapping of a scribe will punch through. The anode button is pretty thin. Even preferred as bgadow mentions.
Old 12-05-2012, 09:58 PM
Yes, I never would have thought about it until I was given a NOS RCA crt from the 80s, like a 27". The instructions inside said to evacuate the dud before mailing it by punching a hole in the anode. I usually use a large, sharp-pointed nail though an ice pick would work well. By the second gentle tap I'm usually through.
Old 12-05-2012, 11:13 PM
Phil Nelson Phil Nelson is online now
Let me know if you figure out how to cut the neck cleanly (hot wire maybe?). I have a couple of dud oscilloscope tubes that could make nice lights.
Phil Nelson
Old 12-06-2012, 06:01 PM
Today was the day - I had myself wrapped up like a mummy, although nothing dramatic happened. First I sharpened up an upholstery regulator(basically an ice pick) and gently tapped that into the HV anode. The anode metal seemed rather soft, and it appeared that the point of the regulator seemed to be helping keep the pinhole sealed. So I agitated the regulator around gently and could then hear the air softly hissing in. I also had a couple clear plastic bags wrapped around the CRT, so those were possibly dampening the hissing sound. Anyhow, mission accomplished. I really appreciated everyone's input. Not so scary anymore.
Old 12-06-2012, 09:54 PM
Down Under's Avatar
Down Under Down Under is offline
It would be cool to see what happened to the picture if you had the CRT running at the time!
Four Predictas down, now to score a Continental.
Old 12-07-2012, 09:47 AM
kx250rider's Avatar
REAL TVs have TUBES!
I've had the UNpleasure of seeing that happen... I had just finished doing setup on a new tube in a CTC-81 back in the 80s, and I let the back cover slip down while I was putting the screws in... A gentle hiss, and in a few seconds, the neck flashed blue, and then the HV started arcing all over the place as I yanked the AC cord out of the wall. The customer wasn't in the room, so I got away with saying "Seems to be a problem with the new CRT... Back tomorrow with another one no/charge".
As far as self-protection for while you're trying to de-bond safety glass to remove cataracts, (or busting a tube to discard if it's compromised or if you're concerned or inexperienced), I wear motocross gear including chest protector, kevlar pants, and helmet with neck roll & stone-proof goggles.
Charles
Old 12-07-2012, 04:40 PM
Penthode's Avatar
Penthode Penthode is offline
When I was a high school student, I worked in a TV shop. Their method was to simply grab a pair of pliers and break off the evacuation nipple. It is safe as it lets the air in gently without risk of implosion.
I would always keep away from the bell of the tube since risking the integrity of the bell could lead to a nasty mess. Knocking the neck off is quick but more risky. Ilike to keep hammers and other heavy metal objects away from glass CRTs.
Old 12-08-2012, 05:36 AM
Down Under's Avatar
How awful! All that work setting up not to mention the cost. You were very lucky that you were alone when it happened. An easy mistake to make, I did similar to a colleague's TV. I hadn't really started to work on it, but the back was off and I knocked the back of the CRT and heard the slow hiss. I felt terrible until I priced what the repair would have cost and realized it was a no goer anyway. Still, it's an experience that's not easily forgotten..
Old 12-08-2012, 01:09 PM
After I aired the 21AMP4 I wanted to salvage it's connector, so I whacked at the neck with a small hammer. Could not believe how hard I had to hit it to bust the neck off.
Old 12-09-2012, 04:39 PM
Down Under's Avatar
I've noticed that, some of the necks seem really thin, whereas others are tough hombres! I use a 2 Kg metal mallet when airing CRTs, plenty of force to be had there, especially if I just drop it onto the neck from about 3 or 4 feet.
Once I had a tube break in such a way that the gun shot forward into the shadow mask! It looked really weird seeing the front of the gun protruding through. The phospor had been blown away from the inrush of air.
Old 12-10-2012, 12:11 AM
Here's a picture of one that did just that. You can see the gun assembly stuck forward in the shadow mask. It actually blew glass off the front of the CRT.
Old 12-10-2012, 01:25 PM
I never heard of any CRT firm, that would want the tube back, not under vacuum.
When you turned in a dud for a replacement, the first thing they did was check for vacuum. They used a hand held high voltage probe.
Old 12-10-2012, 02:15 PM
I remember my sister's KV-9000 Trinitron died several years ago, I laid it face up in a garbage can & proceeded to throw rocks at it to break it...It was NOT easy...Think I finally had to use a cinder block & it took several attempts at that.
