Old 10-07-2013, 09:32 AM
IsthmusTV's Avatar
DuMont Blonde Revere Restoration
Hi all,
I was able to make good progress over the rainy weekend on my blonde DuMont Revere RA-113. This is the set that I picked up at the beginning of August and wrote about in this thread: http://www.videokarma.org/showthread.php?t=258995
I had the advantage of Phil Nelson's excellent write-up on the restoration of his RA-113 which was a great guide (thanks Phil)! Here's the chassis on the workbench before I started:
I decided to replace the electrolytics under the chassis instead of restuffing, since there was plenty of room. The modern replacements are so much smaller!
The flyback looks great. The new HV caps are from Just Radios in Canada:
After restringing the dial cord (which fortunately was easier than I thought it would be) I decided to try a power up with a metered variac. No smoke or strange noises, and current draw was just under two amps.
I got nice clear audio and a very dim raster:
I recalled that both HV rectifiers tested very weak, so replaced them both. Then things progressed quickly.
Here's after adjusting the ion trap:
And after adjusting the horizontal frequency and the other usual stuff:
I'm very pleased with the nice, bright picture! The video response is great enough that I see the color interference dots. There are still 4-5 paper caps yet to replace. The picture is somewhat canted, so I need to adjust the yoke and/or focus coil. And as some of you know, I have what I hope is a new old stock (or rebuilt) 17BP4 that I bought on eBay due to arrive on Thursday. There seems to be plenty of life left in the original 17AP4, but it will be nice to have a spare. The tuning eye tube is very dim, so I'll need to find a replacement.
This was a lot of fun and it's almost a let down at how easy it was
I'm looking forward to watching bandersen restore the one he's got!
-Clark
Old 10-07-2013, 09:43 AM
tvtimeisfun tvtimeisfun is offline
Nice looking set hope you get plenty of tvtime on this set a great find just as well happy veiwing...Timothy
Old 10-07-2013, 01:01 PM
Wow, looking good. All that in one weekend? You work faster than I do (well, I did have a couple of issues like a busted tuner gear). An original 17AP4 suggests this was a low-hours set. Maybe it led a pampered life and retired early.
That blonde cabinet should be really striking. The RA-113 is very enjoyable to watch -- big screen, great audio.
Regards,
Phil Nelson
Phil's Old Radios
Old 10-07-2013, 02:18 PM
brianweber4 brianweber4 is offline
Originally Posted by IsthmusTV View Post
Hi all,
-Clark
That's a good picture!
Old 10-07-2013, 02:59 PM
IsthmusTV's Avatar
Hi Phil,
Actually, I had also done some work on it last weekend, too. And before that, I studied the SAMS and Riders so I knew what I was getting into. (Thanks again for scanning the SAMS folder!)
I do think it's probably a low hours set. The 1/4 amp pigtail fuse was blown and jumpered with a 2 amp fuse At least one of the filter caps was a dead short so it may have been pushed aside quite a while ago. I'm very glad that the seller hadn't tried to power it up.
The audio on TV is still lower than it should be, although the peak for good audio corresponds well with the best picture. The volume receiving FM stations is much louder. I haven't attempted any alignment yet.
It turns out that the original focus control is OK, but I'm still glad to have a back up. Now I'm just waiting to see if this CRT I bought on eBay for $50 make it in once piece:
Old 10-07-2013, 04:31 PM
Hey, that's was quick Nice job! I hope mine goes as smoothly and good luck with that VDC CRT
P.S. brianweber4 could you please edit your post so it doesn't duplicate every single photo ?
Old 10-07-2013, 05:25 PM
Yes, the TV volume was low until I did some tweaking, as noted in my article. The FM radio volume is still significantly louder, and I suspect that is just the nature of the beast.
Phil Nelson
Phil's Old Radios
Old 10-07-2013, 08:16 PM
holmesuser01's Avatar
Impressive.
My RA-113 has 3 15K capacitors, where I see 2 on yours.
Your entire set looks lovely.
Bruce
Old 10-07-2013, 08:37 PM
Yah, mine has three 15KV caps: two above the platform and one below.
Phil Nelson
Old 10-07-2013, 08:39 PM
Nice work, Clark. That sure looks like a super clean chassis. I suppose it helps that these are mounted vertical in the cabinet. Great looking picture you have too.
Old 10-08-2013, 08:53 AM
IsthmusTV's Avatar
Thanks for all the nice comments! I'm really enjoying the high quality of this set. It's the one and only DuMont that I have experienced and it has not disappointed. And mine also has three .00047 uF HV caps, I just snapped the photo before I had installed the one on top of the two 1X2s.
My next steps will be to replace the few remaining paper caps (they're in the little shielded compartment in the sync section) and find a replacement 6AL7. I have also yet to do any work on the cabinet, which fortunately won't need much.
The VDC CRT is scheduled to arrive Thursday by USPS. It's being shipped in its original box which has some water damage. I'm hoping that they double boxed it.
-Clark
Old 10-08-2013, 11:08 AM
So glad to see another DuMont being brought back to life!
Bruce
Old 10-08-2013, 11:32 AM
VERY impressive !
Old 10-08-2013, 01:30 PM
Originally Posted by Phil Nelson View Post
... The FM radio volume is still significantly louder, and I suspect that is just the nature of the beast.
That's true. The deviation of broadcast FM radio is much higher than that used for TV sound. 75KHz vs 25KHz IIRC. This deviation difference results in the FM radio stations being louder than TV station sound.
Old 10-08-2013, 10:04 PM
ggregg's Avatar
ggregg ggregg is offline
beautiful set, Clark. I love that model and the blonde finish.
