Old 04-12-2014, 12:45 AM
StellarTV's Avatar
StellarTV StellarTV is offline
What is this??
Someone sent me pics of this TV today.... What is this thing? The TV channel selector reminds me of a pushbutton Hallicrafters. No name anywhere on the unit, except for the dial glass, which says Telfair Graeme - manufactured for G&E Loit. Looks like a 7JP4 and a late 40s era tube lineup.
No idea of operating condition. Any ideas?
Old 04-12-2014, 01:20 AM
it looks like a hallicrafters chassis , een the knobs are the hallicrafters type, a 7jp4 too , go for it , certainly unique , the speaker is so much bigger then the picture.
Old 04-12-2014, 01:37 AM
I'm going to guess that it's someones home brewed project, the way the chassis are mounted doesn't look like a professional job, plus the spliced in wiring to the CRT socket and the lack of any lettering around the TV controls all say home made.
That's definitely a Hallicrafters TV chassis.
Old 04-12-2014, 01:45 AM
Yes, it's a Franken-TV. Hallicrafters 505/T-54 TV chassis mounted sideways and using extended cables. The CRT is mounted on a piece of wood. The TV is combined with some other radio. Definitely not factory, although the audio may be better than stock with that big speaker.
Phil Nelson
Phil's Old Radios
Old 04-12-2014, 02:49 AM
The chassis in the bottom of the cabinet doesn't seem to be hooked up to anything, I suspect it was the power supply chassis for whatever was originally in the cabinet.
Old 04-12-2014, 08:13 AM
init4fun's Avatar
init4fun init4fun is offline
One of the better looking frankensets I've seen . Weird how that unhooked bottom chassis looks to have a cord wrapped around it , leading me to wonder if it's even bolted in there , or was just thrown in there cause "It looks like more TV parts , maybe it goes with this here old TV we found" (presumably the folks selling this don't have a clue about old TVs , it looks like a yard sale may be going on in some of the pictures)
Old 04-12-2014, 08:23 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Actually, I think it's pretty cool looking. I like the small screen centered in the middle of the big cabinet. It gives it a "pre-war" look.
Old 04-12-2014, 11:08 AM
decojoe67's Avatar
Be aware of this: A friend has that exact cabinet with an genuine factory "Philharmonic" TV/radio/phono. installed. It's entirely original and does not appear to be a "franken-set". It uses a 7" Tele-tone chassis. This set in question could have had alterations, but it very likely was a genuine "orphan" budget combination TV console in it's day with chassis used from different sources. Very cool piece that would be worth restoring in the configuration it is.
Old 04-12-2014, 01:38 PM
TV'S&MORE TV'S&MORE is offline
This looks like a philharmonic cabinet to me too. Like many other companys in those days they used chassis made by other companys. HALLICRAFTERS, SENTINEL and TELE-TONE were the common ones.
Old 04-12-2014, 02:15 PM
I have an IIRC Jensen speaker that looks identical to the one in that set.
Old 04-12-2014, 03:32 PM
I agree. There is a socket on the back of the power supply chassis into which a mating multipin connector, at the end of a multiconductor cable, would be inserted, with an AC outlet next to that socket. This could have been a power chassis for an amplifier or a radio tuner; hard to tell just by looking at the thing. The entire setup indeed looks like a cobbled-together TV-radio combo, with the aforementioned power supply just left in the bottom of the cabinet for no particular reason.
Old 04-12-2014, 04:18 PM
Another possibility: There *is* a similar sized Jones multipin plug on the radio chassis connected to a drooping wire... perhaps the other end of the wire should be plugged into the bottom chassis? I don't see an obvious AC power cord attached to the radio chassis. The AC outlet on the bottom chassis would seem to be in a good location for supplying power to the TV...note the TV cord unplugged, just a few inches away. My guess is that the bottom chassis *is* a part of the combo, but has been unplugged (perhaps for testing?) and is now "loose" in the bottom of the set. Just a WAG, however.
Old 04-12-2014, 08:13 PM
WISCOJIM WISCOJIM is offline
German radio? Loit is north of Hamburg, near the border with Denmark.
Old 04-12-2014, 11:10 PM
EdKozk2 EdKozk2 is offline
Tinker
I think the set looks cool and would be fun to get working again.
Old 04-12-2014, 11:52 PM
Dave A's Avatar
Dave A Dave A is offline
An amazing radio match for the space given in the cabinet. And the CRT has a lot of connections to a base that looks like a Brit tube with the outside leaf contacts...not pins. Does it match the 7JP4 wire count? Don't have mine open tonight. The power supply also seems to have a voltage tap switch on it.
