Old 09-28-2014, 08:06 AM
sampson159's Avatar
sampson159
thats a nice looking set.saw one once.it was in the shop for repairs.very nice set.have to get all the bugs out first before i decide on the cabinet.
Old 09-28-2014, 01:10 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
I have two Avanti (one flat chassis, one vertical). I also have a flat chassis in ye-olde, medieval-gothic dungeon cabinet.
Personally I like the Avante style, but is has to be in a room full of "modern" furniture. The sides are formed plywood. If it is of good quality (probably) I think it would look nice in a wood-tone. Paint the pedestal semi-gloss black.
From Captain Video, 1/4/2007
Old 09-28-2014, 04:11 PM
Adam's Avatar
Adam Adam is offline
Originally Posted by Jeffhs View Post
… It seems that you used an old console TV cabinet, with a shelf installed, to display the radios. This seems like as good a solution as any to the problem of cats jumping on shelves and knocking the radios off. ...
That's just an old cabinet with the doors missing, I used to use it to hold books and records, but I thought it would be a good place to keep radios and tvs. I keep the radios down low now. Although on the top (not seen in the picture) I have a bunch of VHS tapes that keep getting knocked down
Originally Posted by Jon A. View Post
...Ron, this 1979 System 3 console should give you a good idea of what your Avante wold look like in black. Looks like the base is chrome-plated, very nice.
That's one of the very few system-3 era Zeniths I wouldn't mind having. But I've never seen even one. In comparison, I've seen loads of those ones in the silver plastic curved cabinet which I don't think looks nearly as nice.
I think the Avante would look nicer with finished wood on the sides and a black base than painted black on the sides with a white base, but then I like them the way they came white with the white base.
Old 10-03-2014, 02:57 PM
sampson159's Avatar
sampson159
reseated all ic s,went through color circuit.no change.it might be an ic.no progress made so far.shiny black is looking pretty good right now!
Old 10-04-2014, 07:27 AM
Put normal-align switch in align ( not the service switch ).
Adj. APC control for least amount of color bars going through
picture. Go back to normal & see if its better. & dont forget
that 330 ohm, it can cause some subtle problems when
just starting to go.
Old 10-04-2014, 08:52 AM
Is that the 330 ohm resistor on the 9-90 board?
Old 10-04-2014, 11:54 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Those curved Zenith cabinets are among the ugliest TV cabinet designs in my opinion, but as I always say, ugly sells. A Chromacolor II in a cabinet like that I would try to get for parts, a System 3 I wouldn't touch.
Old 10-04-2014, 03:40 PM
In the flat chassis 9-57 IIRC. Same resistor & function. IIRC
the only difference from 9-57 & 9-90 is the connectors are staggered on the
-57 & in a row on -90 but near identical otherwise.......
Hybrids, flats & uprights are much the same circuit wise.
Old 10-04-2014, 03:44 PM
Must be thinking of the "panorama" set. Built to sit in a corner. Very good seller but if you like modern sets there were better lookers than that
one at the time IMHO.
