Old 01-18-2016, 09:43 AM
LovesZenith LovesZenith is offline
Antenna Connector
This one is kind of an strange question, but this seems to be the best place to post it. I recently acquired a 19" tin can Zenith (my first tube set, but that's another post for another day) and it still has it's rabbit ears on the top of the set, it has the little pitchforks to screw onto the back of the set. A while ago, in a video on YouTube, I saw a device that you screwed the pitchforks into, and then you could plug it into the modern day out puts on your converter box. It let you use the original/analog antennae built into the set. It was just a nub really, with two screws on one side, and a cable out put on the other. Does anybody here know what I'm talking about, and what it's called? I went to two different Radio Shacks, and one only had converter boxes, and the other had the things that you screw onto the back to plug a cable into. I hate that I can't find the video I saw it in, because I remember them saying what it was called. So, if anybody know what I'm talking about, please leave the name so I could order one online.
Thanks,
David
Old 01-18-2016, 10:03 AM
Gunslinger Gunslinger is offline
300ohm to 75 ohm adaptor. It is called a matching transformer. I have a ton of them.
Old 01-18-2016, 11:12 AM
Thanks a bunch! One's on its way right now.
Old 01-18-2016, 12:40 PM
It is definitely fun to receive digital TV signals with old rabbit-ear antennas.
Old 01-18-2016, 02:40 PM
Radio Shack does carry TV antenna matching Baluns.
Old 01-29-2016, 04:28 PM
TVTim's Avatar
TVTim TVTim is offline
No more Radio Shacks in my area. They are all, sadly, gone.
