Old 04-26-2016, 04:12 PM
earlyfilm's Avatar
Eternal Member
Originally Posted by Kamakiri View Post
Everything's lighting, and I have a full raster.
On pin 3 of V1, I have nothing. Should be 52 VAC.
If you have zero volts on filament pin 3 of V1 then it ain't lighting!
You should have 6.3 V AC between pins 3 and 4 of V1.
If V1 filament is not lit, then it will draw no B+ current and your voltage on pin 1 plate of V2a mixer will be too high, as you mentioned above, because both are after the same B+ load resistor.
James
Last edited by earlyfilm; 04-27-2016 at 06:37 AM. Reason: clarified poorly written sentence
Old 04-27-2016, 07:30 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
The wife was a bed hog last night, so I woke up at about 4 AM and decided that I was up. Here's where I'm at.
I cleaned the snot out of the pins on V1 and now have correct voltage on pin 3. As to whether it was lighting before, I was fairly certain, but who knows....it was early this morning....so I just went ahead and cleaned the pins and the voltage was there.
The voltage on pin 1 of V2 is still unchanged.
Going to toss this set in the van and have Tom (Electronic M) take a peek, as long as we'll be seeing each other at ETF. I might bring the other tough dog 7" for my replica pre-war too....spread the fun around a little, and maybe I'll learn something in the process
