Old 09-20-2016, 09:20 PM
Adam's Avatar
Adam Adam is offline
cassette player belts?
I recently picked up two Zenith MC9070 audio cassette players. They both need belts. Can you still get these anywhere?
Old 09-21-2016, 09:17 AM
ed857 ed857 is offline
Might try here : http://www.fullcompass.com/
Old 09-22-2016, 12:20 AM
maxhifi's Avatar
maxhifi maxhifi is offline
www.turntablebelts.com
Have used them several times, for teac, Sony decks, with good luck
Old 09-25-2016, 01:32 AM
colectorad colectorad is offline
On Ebay, there are assorted multi-size packs of square cassette belts, usually 30, 35, 50, or 100 belts per pack. Flat belts as well, but to a lesser extent.
You'll need to know the type (flat or square) and the circumference of the belt(s) that you need. Wrap a string around the pulleys and mark the overlapping point with ink. Measure the string and you'll have a close approximation of the circumference. Some sellers measure half the circumference ("fold long") or the diameter instead, but both can be calculated from the circumference.
I'm in need of service manuals for the following:
Magnavox 19C315-CC, Emerson ECT-1300A (TM0110E), Sears 401.50300900
