Old 06-24-2017, 12:00 AM
CRTs4life CRTs4life is offline
Sony standby blinks twice-Adventure
Hello ladies and fellas.
Maybe someone has some input they could share.
Recently I was given a Sony KV-24fs120, dated Dec 2004, BA6 chassis. I had no idea if it even worked or not as I have another and would save this for parts regardless. As it turns out it did not and produced the 2 blink diag code. This TV falls in the sweet spot for gamers 19-(20-25)-27" and I decided to attempt to fix it.
Here's what I have:
Nothing burned or smell. Fuse is good, double checked with dvom. I found no swelled or leaking caps. I went over the entire underside and found no bad joints either.
Jumping the gun, before gathering more information, I went ahead and replaced the ic chip that comes up quite frequently as the culprit. Note*-this model only has 1 chip versus 2 on many Sonys. After replacement I plugged it back in and no change, still the same 2 blinks. @#$%&!!!
Long story short I am leaning towards the "hot" horizontal output transistor and also the flyback transformer. After reading and reading this is what I came up with. (I think)
See my enclosed pictures. After I went back and looked at things again, I can say that flyback has A LOT of miles on it.
Does anyone have an opinion on this? I know too well to put genuine Sony parts back on it but I see aftermarket parts around. Are any of those any good? Electronix?
Before I go spending more $ I figured I would ask. Thank you in advance.
P.S.-Has anyone ever used another flyback from a similar TV say like a kv-27fs120? Part numbers are a task to find as well.
Again thanks.
Old 06-24-2017, 12:42 AM
mrjukebox160 mrjukebox160 is online now
I would test the CRT before I put much time/money in it.
Old 06-24-2017, 08:42 AM
IIRC 2 blinks are over current shut down. This will almost
always be the horz output (HOT) & or flyback ( FBT). FBT's did go
often on them. WARNING IIRC most of the FBT's were shipped
without the HV lead & you needed a special tool to get the old
one out !!
If the HOT is shorted the horz drive transformer usually has
cold joints or the FBT killed it.
Old 06-24-2017, 08:57 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Attached better photo
I JUST scrapped a 27" Sony from 2005 with a bad CRT. I cut a couple of wires that go to the fly, hopefully it isn't buggered.
I hope the HV wire on this one is modular because I cut that too.
Old 06-24-2017, 09:42 AM
Well, I do have the other TV I could swap the board out of easy enough. It's so nice, I almost hate to disturb it. I have to find out this special tool to disconnect the hv lead. I'm a career auto technician so I might be able to make something work with what I have at hand.
Has anyone ever just soldered those leads back together? That's really all I was planning, sort of. My joints always have virtually no voltage drop. Just saying.
I'm not in a hurry, I can sit on this. I'd love to resurrect it though, besides the size-component is sure nice to keep.
Is there one place better than others to buy parts?
Old 07-29-2017, 01:08 AM
Well the moral of this story is to be patient and like @mrjukebox160 said "check the actual tube (if you can) to see if it is even worth bothering with.
As an update, a couple weeks back I found a seller of multiple Sony CRTs, all with barely any use as his elderly mother bought them late in her life.
I came home with the same model 24" that I started the thread about, kv-24fs120, and his little sibling a kv-20fs120. He wanted more but I offered $80 and he accepted.
A Super Nintendo with an s-video cable really looks good on these televisions I have to say.
Thanks again for everyone's advice!
