Old 01-26-2018, 12:55 AM
southernguy southernguy is offline
T-995-02 70's Magnavox Tripler Failure.
I am looking for a Tripler for a Magnavox T 995-02. This set was giving to me by a family member, it has the twin high voltage lead. The horizontal output transistor is probably toast. CRT tested strong so I thought it might be worth to try to repair.
File Type: jpg 20180121_160319_crop_604x604-302x302.jpg (29.3 KB, 24 views)
File Type: jpg 20180120_225101_crop_604x604-302x302.jpg (23.0 KB, 27 views)
Bruce Janey
[email protected]
Old 01-26-2018, 08:34 AM
OEM # is 530165-10
Subs to NTE534 and others.
2nd wire goes either to a focus divider or bleeder.
On these sets its best to pull the chassis & resolder the mother board
especially at the module plugs & the frame lugs that are often grounds.
Then pull the modules & resolder those contacts. Some of them
had plug in flybacks. Be sure the pins are clean. Ive seen a few really
brew up.
