Closed caption generator chips?
Hi, I'm doing some work with extracting bitmaps from character generator chips like those used in closed captioning from the 90s. I've currently got three:
STM STV5730A: ![]() Maxim MAX7456: ![]() And Mullard SAA5050: ![]() (Not super accurate yet, cause it does some internal smoothing) I'm looking for the names of similar chips, as they usually have the bitmaps in the datasheets. I'm specifically looking for ones used in closed captioning, these tend to be more for VCR displays and such, which limits the number of characters they implement. |
My telecaption vr-100 decoder box has ITT NCI LN21 G010279.000 3224.20, a brandless KA2919 236A, and some smaller 74 series logic and other chips that I'd guess are op-amps and such.
I don't have anything. Is this for some kind of project you're working on, or is it just research?
It's for a software project I'm working on which lets you generate closed caption images.
I'm converting the rom contents to bitmaps for placing over screencaps. I'm just trying to find specific chip types that were used during this time to make it accurate (rather than just getting an arbitrary similar looking font) |
There are a few various decoder fonts out there in TrueType, and a few more 'locked away' in long-discontinued decoder chips. Built-in decoders in sets used caption decoder chips in the early years, then 'graduated' to using the same chip used with on-screen menus. Sony and Trinitron Akai used the best-looking fonts of the day. The 'no descender' fonts (shown in your post) are kind of the classic, so-ugly-they're-cute fonts.
When you 'extract' these, is it destructive to the set/decoder, or to the chip? Or could you work with a digital file of the on-screen presentation of all the characters, as brought forth by the caption encode/decode process? I have a collection of good, bad, and fantastic caption decoders (and similar devices) from the past 25 years or so. Also have equipment to generate and harvest both 608 and 708 caption data in any format. Don't overlook the nice-looking caption fonts in QuickTime, too... In pro broadcast hardware, EEG has some great-looking decoders. Evertz has some lousy ones. They both cost $3000. Most current-day caption displays are driven via graphics chips within the set-top box, be it cable, satellite, or OTT/AppleTV/Roku-type device. The internal caption decoder in current sets is only used with over-the-air broadcasts, since the HDMI cable spec has no 'lane' for caption data at all. As captioning progressed over the years, the allowable character sets expanded as well. First-generation was pretty limited, with barely enough character set support for English, Spanish, French, etc. Later versions (Telecaption II compatible stuff) expanded that set a bit, but limitations still existed. Limitations, like decoders couldn't display an asterisk *, for example, not because of chip limitations, but it was an 'illegal' character in caption data. Once HD/708 captions hit the scene, there was no practical limit to characters, and fonts/attributes were more in the hands of the viewer, and varied by set manufacturer/graphics chip design. - Chip (Closed-captioner for 25+ years. Feel free to PM me if you'd like.) Last edited by Chip Chester; 05-11-2018 at 09:36 PM. |
How about the 2513 chip made by Signetics and GI? Sometimes called RO3-2513. There are several versions out there depending on what alphabet you get. (You can even get it with Kata Kana).
The newest version uses only one 5 V supply but the older ones used +5,-12, and +12. Not pin for pin compatible.
I don't know if this one was used on closed-captioning, but it was used everywhere else, from early dot matrix printers (Centronics 101, LA30 DECwriter, Facit 4553, Extel 70 teleprinters, Practical Automation printers for receipts and ticket stubs) to electronic signs (on some days at the Summer 1976 Olympics in Montreal, and most notably the zipper at One Times Square in New York from 1971-72 to 1977 when the Reuters news agency operated it). The question is which company originated this (I presume Digital Equipment Corporation) and what numerical code was used for it. It was associated with PDP-8 systems, for sure, and dates as far back as at least 1970.
Below is the character map with octal codes from 040 to 137, plus the type as it looked transmitted through said 11-row high Times Square zipper. Which firm would have used this type for scoreboards such as said Olympics? |
I think the Zipper dates back to pre-WWII and used electromechanical scrolling originally.
They used different fonts. I'm enquiring about this specific type that dates to at least 1970 and precedes by some years the creation of Signetics and General Instrument's RO-3-2513. Surely someone has to have knowledge of PDP-8 and all to zero in on the origin of the type redrawn from various graphs, photos, and printouts.
Don't forget Baudot code. Its 5 bit.
Those alphanumeric characters I brought up were the first computer-based type to use ASCII. Baudot, however, was used by Time-O-Matic in the mid-1960's for their product lines of controls for traveling and changing message signs (typed on what appeared to be a Teletype Model 33 with perforator tape).
I am also enquiring about the origin of the 7 x 9 dot matrix font that was on many a Tektronix color bar generator, with the characters scrunched up to look thinner. Here's what I could gauge on their alphabet. It wouldn't be Atari, that I know.
(Those that are blank, other than the space on the top most left, I have no idea how the characters in this set are shaped.) |
If you can't see that illustration, here's a larger one:
