Old 01-02-2019, 09:39 AM
Perhaps I missed something, but how did you make such clean cuts? You got a CNC laser cutter or something similar?
I cut the Masonite close to the lines with my band saw or Dremel jig saw, then on the outside edges I used my disc sander. On the "inside" edges, I just filed them to the line, and everything got a light sanding with 220 grit sandpaper.
The holes were drilled using a1/4 "Brad Point" drill bit.
Old 01-02-2019, 12:53 PM
Tip on getting a very clean cut on wood or fiber board with a jigsaw: get a tile cutting blade. They are basically a diamond powder sand glued to a smooth metal. They cut wood very clean but limit the jigsaw turning radius and cutting speed a bit... They also cost a good bit, but when you have a tiling home improvement project that justifies the purchase.
Old 01-02-2019, 05:18 PM
Thank you... “Brad Point” drill set added to my vocabulary and my shopping cart.
Is the Dremel jig saw a hand-held device or is it configured more like a small band saw (scroll saw)?
Old 01-02-2019, 05:22 PM
Tom,
Thanks for the tip!
Old 01-02-2019, 05:27 PM
Old 01-02-2019, 05:29 PM
All done!
Old 01-02-2019, 07:15 PM
kvflyer kvflyer is offline
I cut the Masonite...
Brad point drills are the solution. They cut without ragged edges and since they have a point, they do not "walk" or hog out the hole.
Crist, did you use some kind of jig to keep the holes in a perfect line?
Old 01-02-2019, 07:23 PM
No. I just center punched each one. There were a lot of holes!
Old 01-02-2019, 07:42 PM
Thanks...
